Pool Re-startup
Jun 8, 2007
86
Arkansas
I made the mistake of never taking my pool down last year.
I drained the water, but over the coarse of the fall it has gotten leafs in it.
The water is all pretty much dry in it now, so getting the leafs out won't be a big problem
My question is what's the best way to clean all the other junk out?
My drain isn't the lowest point in my pool (never are on above ground pools)
I tried earlier this year to use a shop vac to get it all out, but even a big shop vacume fills up fast and gets frustrating.
Should I just scrub the pool walls down, fill the poll up with a bit of water and drain it several times?
If I can get it clean now, I'll have less problems later as I will put my cover on top of it and keep an eye on it.
