Thread: Nature 2 question
    Feb 2008
    Denton, TX
    5,061
    Nature 2 question
    Having purchased a home with a pool that has a Nature 2 system, I am wondering whether or not to continue to pay any attention to this device as it appears that the jury is really still out as to whether or not it is a beneficial piece of equipment. I have had more than one pool person tell me that they are more or less a gimmick and that the only thing I need to do with it is remove it completely when it begins to leak from age. Thoughts?
    Craig
    Jan 2008
    Burbank, IL
    109
    I think the general consensus is that the Nature2 is something you can live without.
    Wilbar 12 x 17 Buttress Free AG (~4400 Gal?)
    Hayward 225 sq ft cartridge filter
    1/2 HP Pentair Whisperflo
    Liquidator chlorine feeder
    Pool Rover Jr.
    BBB - it's the way to go
    The Nature2 system adds copper to the pool. Copper does help against algae (which you can see), but it doesn't help significantly against bacteria, viruses, and parasites (which you can't see) so it can create a false sense of security. Also it is possible to get unsightly stains which are difficult to remove from having copper in the water. You have to use chlorine even with the Nature2 and chlorine alone is sufficient, so why bother with the extra expense and possible risks of the Nature2 system?
    Feb 2008
    Denton, TX
    5,061
    The Nature2 system add copper to the pool. Copper does help against algae (which you can see), but it doesn't help significantly against bacteria, viruses, and parasites (which you can't see) so it can create a false sense of security. Also it is possible to get unsightly stains which are difficult to remove from having copper in the water. You have to use chlorine even with the Nature2 and chlorine alone is sufficient, so why bother with the extra expense and possible risks of the Nature2 system?
    This is what I gathered. I have no visible stains as far as I can tell. Perhaps I could simply pull the cartridge from the system and just leave it alone then?
    Craig
    Yes, that is a good plan.
