Aquarite problem
mk1
Platinum Supporter
125
Miami Beach, FL
So I was getting low salt readings and flashing check cell and check salt LED's.
I know my salt was actually a little high by test kit assay.
Cell is clean.
So I decided it was symptomatic of my 3-4 year cell dying and bought a new one.
NO change in readings or LED's
All my voltages/amps are in spec too....
Thoughts?
OK, been awhile but...
Unit still reading low 2100 and not generating despite multiple tests showing 3200-3400 salt.
pool temp is 80 degrees.
New cell.
No burnt parts on board, fuse is good.
I replaced the black disc anyway just in case.
I guess I will by a new main board unless someone has an idea?
thanks
You didn't see any burn marks on or around the varistor like this(actually cracked)?
