mystery device on a pump pipe
Feb 22, 2011
8
hi all, was hoping for a little advice -- the answer is probably very obvious.
On one of the pipes to the filter, there is some sort of tiny device (sensor?) that is attached to the pipe by a metal band. This device has a small wire which connects to the pump. Here are a few pics of it.
[attachment=2:11gm1w6g]IMG-20110815-00089.jpg[/attachment:11gm1w6g]
[attachment=1:11gm1w6g]IMG-20110815-00086.jpg[/attachment:11gm1w6g]
[attachment=0:11gm1w6g]IMG-20110815-00088.jpg[/attachment:11gm1w6g]
Well, there is a tiny leak from the pipe, right where this little device sits on the pipe... it... it sprays out in a tiny little jet of water constantly. Do I need to have this pipe replaced? Is it a complicated job due to this little device? Can someone tell me what this device is? thanks in advance!
ahhh.. i think you guys are right... the wires seem to connect to the automation system. (it does display the temp of the pool and spa separately). So, does this sensor pierce the pipe to measure the temp? Or does it just measure the temp on the outside of the PVC-ish looking pipe? Trying to figure out if I should try to fix it myself... thanks!
There should be a small hole drilled int he pipe for the sensors probe to touch the water. The sensor probably has a piece of gasket material sealing it to the pipe and the clamp holds it on tight. Maybe just try tightening the clamp first to see if that stops the leak. If not, I would pull the clamp off and inspect the sensor and how it seals to the pipe = it might just be epoxied, or oring around the probe or gasket material. This is definitely where you are leaking.
