Thread: Add DE to a cartridge filter system?
    Jan 2008
    Las Vegas, NV
    20
    I have a pentair clean & Clear plus 420 (4 vertical cartridge) system and was wondering...the instruction manual says add .75 lb of DE into the skimmer for each 100 sq feet of cartridge surface, it will improve the filtration. I had been planning on adding 3 lbs of DE to the skimmer.
    I just added new filters in NOV.
    I went to the pool store and a fairly knowledgeable pool guy said not to do that, it would plug the filter...
    What say you all?!
    11070 gal Gunnite, Tahoe blue pebbletec, free form
    Pentair 420, PCC 2000 in floor cleaner, waterfall
    2 - 1 HP whisper flow pumps (floor cleaner & main)
    1 - 1 HP Pentair Waterfall pump
    Some cartridge filters will be destroyed the instant you add DE, others are fine. If your filter manual says that you can do it then go for it. If the manual doesn't specifically suggest it then better not to.
    Guest
    The DE is to be added only the first time the cart is used. It does plug up the cart a bit and help improve filtration butrepeated use will ruin the cartridge.
    TexasTwister's Avatar
    Feb 2008
    Richmond, Texas
    37
    Would this also hold true for the Purifiber product?
    15,323 gallon inground pool, Wetedge Primera Stone plaster, Pentair IntelliChlor IC40 SWG, Pentair IntelliFlo 4x160 pump, Pentair Clean & Clear Plus 420 cartridge filter, Pentair EasyTouch control panel, Pentair Kreepy Krauly. No spa, no heater.
    The fiber products don't become embedded in the filter fabric so they are normally fine for ongoing use.
