Thread: How do I drain some water out?
    Sep 2007
    Madisonville, LA
    83
    We have had a lot of rain lately and my water level is almost to the top of the coping. The deck has not been poured yet so the overflow has not been installed. I have a cartridge filter setup, hence no backwash plumbing. How do I use the pump to lower the water level?
    Lee
    10200 gal 12x24 IG vinyl, Dual Main Drains, Sta Rite System 3 cartridge filter, 1.5 HP pump, Zodiac LM3 SWCG, Letro Platinum w/booster, Colorlogic, Spraydeck, Deck jets, Oasis 36" Arch Waterfall, custom built BBQ island
    DONNIE's Avatar
    Mar 2007
    OKLAHOMA
    122
    Do you have an outdoor type faucet installed in your pool plumbing? If so you just need to hook a garden hose to it and open it up. It will only work when the pump is running.
    8500 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    You could also setup a siphon to lower the water level.
    If you want to use your pump you'll have to rig up an attachment to connect to one of your pool returns and run that out of the pool
    21,000 gal Fiberglass (Indoor)
    Feb 2008
    45
    You should have a hose bibb (faucet) attached somewhere between your pump and filter (at least that is how I've always seen it done) just attach a garden hose to that, open it up and kick on the pump. This will allow you to drain a few inches off the pool. It's not terribly fast, and it will usually only drain till the water is at the bottom of the skimmer. (where the pump will start to catch air) If you're in a hurry, get a submergable pump, they're much faster and can come in handy in the future.
    Sep 2007
    Madisonville, LA
    83
    Overflow pipe is now installed off of skimmer. Water level remains constant after rains.
    Lee
