Thread: Pool Cleaning
    Jun 2007
    Pleak, Texas
    32
    Pool Cleaning
    We have a 24' above ground pool. When we bought it (used) it came with a Manta suction-side cleaner. It does a moderately acceptable job. But it requires monitoring when it is running because at various times it has suctioned up the side of the pool to the top and started inhaling air, the tubing randomly collapses, and the flexible rubber plate-shape on the head occasionally falls off.
    So I was thinking about getting a different kind of auto cleaner and even debating putting in a dedicated suction line instead of going through the skimmer.
    I can't afford a lot here, but I want something I would be happy with. Anybody have any suggestions as to brands/type? Would a dedicated suction line help at all? Where is the best place for locating a new suction line?
    Eddie
    Mar 2007
    Coastalish 'down easter'
    4,160
    Eddie, why not just vacuum the pool manually? With a round AG pool, everything should settle into the center of the pool - it'd take ~ 5 min to do it every few days. Then you don't have to worry about the auto cleaner sucking air or loosing it's pad. With everything getting more expensive almost daily, save the $ and manually vac a couple times/ week and don't worry about spending $$ on installing a new line or buying a new auto-vac
    Luv& Luk
    -Ted
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Quote Originally Posted by waste
    Good Advice! If you don't have a lot of trees around you could probably do it once a week. It would take 20 minutes.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Jun 2007
    Pleak, Texas
    32
    Because I'm lazy and was trying to get out of that.
    I was looking at the cheapo manual vacs at lowes the other day - or they any worse/better than any of the other ones out there?
    Eddie
    Aug 2007
    Pensacola
    129
    I am sorta in the same boat as pleakpool. I use a sta rite little shark automatic vacuum which would be fine except that it constantly gets stuck in different spots against the wall and has to be bumped back on track. Other than vacuuming manually, what are some automatic cleaners that you guys could suggest to us that work better than what we have now? Maybe something like the kreepy krawly or dirt devil?
    24' AGP vinyl, 3/4hp Pentair 2-speed, Pentair Quad DE 60
    Pool Rover Jr.
    TF-100
