Water level bucket test
With the bucket being on a step in the pool you will have the same evaporation effect in the bucket as the pool. Both will loose the same amount of water. I don't think there is a set time frame to watch for changes. If you have a small leak you may not notice a difference for a few days between the two. Do you have an auto fill on your pool? If you do make sure it is off while you do the test.
