Thread: Did I buy the wrong stuff?
    Bucks Count PA
    73
    http://www.poolgeek.com/ProductDetails. ... =TechSpecs
    I was wonerding if I bought the wrong stuff the link above takes you to the product I bought. When I order I thought it said Poly Quat 60% but it only says Poly something or other not Quat.
    Would it be ok to use it if it is the worng stuff?
    Inground Grecian 20,000 gallons vinyl liner
    Hayward 250 BTU Propane heater
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    You indeed bought Poly Quat 60
    The whole name is Poly[oxyethylene (dimethyliminio)- ethylene (dimethyliminio) ethylene dichloride]
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Bucks Count PA
    73
    Thanks!!
    I didn't see the word quat so I got worried.
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    Michigan
    11
    Thanks For The Buy!
    Thanks For The Purchase!
    Matthew Austin
    PoolGeek.com
    1-888-354-Geek
    Coupon Code: TFPoolGeek
    Save 10% Any Purchase
