andy said:
12-23-07
End of day test results
Pool Pilot test results:
Cell= 0V 6.5A
Amp-Hrs 002191
351 oz acid fed
ORP 653 (640)
PH 7.57 (7.70)
Taylor results:
FC 2.6
CC .8
PH 7.3
TA 130
CH 400 this one is always hard to read because I seem to get more purpleish blue
CYA 0 slightly dull at 30ppm
OK here are a few of my thoughts. First of all this is a swimming pool and not a science experiment so get a grip! (Sorry if that sounds rough but too many people get hung up on the small stuff and forget to see the big picture! It's a pool, not the space shuttle!)
Now for a few constructive (hopefully) observations.
CYA messes up ORP readings. Very low levels of CYA are probably not going to make much difference but be aware that this is one of the biggest drawbacks to ORP controllers in swimming pools. Also, both the ORP electrode and the pH electrode need to be properly calibrated (and this can actually take some time to do properly, which is why I don't think they are the best thing for residential pools unless you really understand the science behind them.) I suspect that yours might be out of calibration given the pH discrepancies you keep reporting between the pH readings and the phenol red pH test.
If there are no phosphates in your fill water then the phosphates most likely came from the phosphonic acid based Metal Magic, which can convert to orthophosphates in the water. You said you had brown stains. These are usually indicitive of iron but you also said that you have a fiberglass pool and copper can cause brown staining on fiberglass. If you have a heater that has a copper heat exchanger it could be a source of the copper. Might be worth while to have your water tested for metals but be aware that the sequesterant will mask the test results if you are still using it. Also, you said that after shocking you had a sand like grit in the pool. You did not say what you used for shock (cal hypo, sodium hypochlorite, etc. but be aware that high chlorine levels can cause metals to precitpitate out of solution and that cal hypo can cause calcium carbonate to precipitate out also. Either one could look like a grit on the bottom of the pool but the metals would most likely have a color and the calcium would be white. I would not worry about using a lanthanum based phosphate remover since you do not have a problem with algae or not being able to maintain a proper FC or ORP reading. The only way that I know of that phosphates can contribute to CC is by allowing algae to bloom and the residual chlorine cannot take care of it. Since this is an indoor pool I assume it's exposure to sunlight is minimal so I would not expect algae blooms to be a major problem. However, a pool with high phosphates might also have high nitrates/nitrites and these can cause persistent CCs.
Keeping a pool covered all the time will lead to persistent CC formation in the water. Uncovering the pool and keeping it uncovered for a period of time can help by allowing the volatile CCs to gas off but an indoor pool often has a problem with persistent CC since the atmosphere above them is a closed system unless the ventilation system is really excellent. Since you are using ORP controllers I would not recommend using MPS. This will mess up your ORP readings and cause too low a chlorine level for properly sanitized water! ORP measures the oxidation potential of the water and MPS is an oxidizer but NOT a sanitizer.
Now as far as your testing methods....I can help you with the CH test, which most people do wrong. If you are getting a purple color that is known as a 'floating endpoint'. It is often caused by metals in the water. Since you have been using Metal Magic I assume you have a metal problem (otherwise there is no reason to be using a sequesterant). You mentioned brown staining, which is often from iron.
To test the CH first add 6 drops of the calcium titrant (3rd reagent) to your 25 ml sample and swirl well (about 20 seconds).Be sure to include these 6 drops in your drop count for the titration. Next add the 20 drops of calcium buffer (1st reagent) and swirl well. It is important to mix these well and give them time to react. Now add 5 drops of the indicator and swirl to mix. Now the important part of how to do this test. Add a drop of titrant and swirl for 20-30 seconds before adding the next drop. You need to swirl the vial between each drop for 20-30 seconds. If you do this you will not get an indistinct purple color which, if you look close is actally purple 'floaties' in a blue liquid. It takes a while to do this test properly, especially if your calcium levels are high. The only way to speed up this test is by using a magnetic stirrer to insure complete mixing of the titirant.
A few other observations. I would lower the TA a bit, expecially since your calcium is at 400 (and might possibly be much higher since you have never reached a true endpoint. )
To know when a titration test is done you keep adding titrant until adding one more drop does not produce any additional color change and then you don't count that last drop.
Finally, I find the fact that your CC seems to stay constant at .8 ppm no matter what you do indicates one of a few possible things. The first is testing error. I would have someone else do the test with your kit and see what they get. The second is that there are some non volitle CCs in the water that are only going to be removed by 'nuking' the pool with extremely high chlorine levels or by draining and refilling. I would recommend testing the water for nitrates and nitrites (Not normally done with pools but can cause either a large chlorine demand or persistant CCs.) You can use an aquarium test kit to test for the nitrates and nitrites. Ideally they should be both be at 0 ppm. Unfortunately, the only way to lower nitrates and nitrites is by draining and refilling.
If it were my pool the first thing I would do is make sure my electrodes are properly calibrated. The second thing I would do is keep the pool uncovered for at least a few weeks to see if the CC readings change. I would stop using a sequesterant if I did not have metals in the water but I would not worry about using a phosphate remover at this time. I would test the water for nitrates and nitrites and if present would drain and refill to get rid of them.
Finally, if all else fails I would accept the fact that many indoor pools have a high level of CCs that are persistent and that mine might just be one of them.
Your situation is complicated by the fact that you are using ORP controllers so that really removes a few of the options at your disposal. Keeping your pool uncovered is probably your best course of action, combined with regular shocking with liquid chlorine. You might need to go higher than the 10 ppm that would be customary in an unstabilized indoor pool,however.
