Sorry, it is a little confusing. I have a paver patio and my pool will be on the west side of that patio. Also on the west side of that patio is an unfinished portion of my basement that has the electrical panel and a gas line right there. If i put the skimmer on the north/west side of the pool contrary not the best spot for wind, I would have a short run to a place where I could locate my equipment and have easy access from the unfinished portion of my basement for electrical and gas.
If I put the skimmer on the east side where directly where the wind blows, my patio would interfere with me running any utilites to it from the unfinished portion of my basement, unless I ran the pvc piping completely around the round pool like 300 degrees. So the alternative would be to run the utilities to the opposite side of my basement which is finished and essentially the electrician and plumber would nee do run everything to the opposite side of the house, thru a drop ceiling and thru all of the joists.
In a nutshell, the problem is my patio interferes with any direct routing of utilites and piping if I use the best spot for the skimmer. So I would need to run all of the utilities to the opposite side of my house and patio to hook up to the skimmer on the east side.
