Thread: Carcinogenic concrete dust getting into pool
    Sep 2007
    Toronto
    106
    I am in the middle of a fiberglass swimming pool project. The concrete coping around the pool needs to be straightened since the foam moulding did not hold well when the concrete was being poured and certain areas have bulged out. My concern is during the concrete cutting process, all the concrete dust will fall into the water, since this is a figerglass pool, water is already filled. Will my filter be able to pick up the concrete dust? I know concrete dust contain silica which can cause cancer.
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Ke, welcome to TFP
    There are a couple of things which can minimize the amount of dust that gets in the pool while cutting the deck. #1 is to use a wet saw when cutting the crete , the saw should have an adapter to hook up to a garden hose which turns the dust to mud. Also cut so that the discharge from the saw is pointed away from the pool. If for some reason the wet saw isn't an option, you can float a sheet of plastic on the pool to catch most of the dust, what little bypasses the plastic can easily be vacuumed up.
    The danger from the dust is if it's inhaled, a particle mask will provide sufficient protection.
    Good luck with the repair, if you have any other ?s - just ask
    Luv& Luk
    -Ted
    Sep 2007
    Toronto
    106
    Thanks for your reply. The plastic sheet is a good idea, I will probably also tape the sheet to the pool wall so all the dust will stay on top of the plastic sheet. They will also do some grinding after cutting the concrete.
    OH TWINS
    The usual way is to make a temporary pool cover out of bubble wrap taped together
    with duct tape. When the job is done just throw the whole mess away.
    Cliff s
