No Suction In Main Drain
Jun 28, 2011
13
Hi All! I'm not only a newbie to the forum but also a newbie to taking care of a pool. The wife and I just bought an older home and it has a pool with what looks to be older equipment. Ok, here's the deal.
When I purchased the home there was no drain cover in the deep end. I bought a new cover and swam down to install it yesterday. To my surprise, there was no suction. I stuck my hand in, nothing. I got back out, played with the Jandy valve in every which way, nothing from the main drain. I can get sharky (the automatic pool cleaner) to work great, I can get the skimmer to suction, but nothing from the main drain. On top of that, my automatic pool cleaner only works with FULL flow. I cannot have the skimmer pulling water or there is not enough power to move the cleaner.
There are 2 lines that go into the Jandy valve before making their way into the pump. I would assume one is for the automatic pool cleaner and the other is for the skimmer & main drain. Please help! I'm pretty self sufficient but completely new to pool care.
Ok, I have a bit more information now. I've included the pool specs that I know in my signature and have attached a few pictures. There is definitely no labels on the plumbing but there are 2 holes in the skimmer. I've attached a picture of that as well. Let me know what you think. As always, thanks so much!
It looks like one hole in the bottom of the skimmer is plugged?? Is it?
Where does your cleaner plug into the pool at?
I'm thinking that the two lines coming into the Jandy valve are the skimmer and the MD (main drain).
I'm pretty sure that hole is not plugged. I'll check again but I believe that was just the way the pic turned out as it was getting dark. The automatic pool cleaner plugs into the pool a few feet away from the skimmer, maybe a foot below the surface of the water on the wall.
I think your right on the Jandy valve. My biggest concern was that there was no flow (that I could feel with my hand) in the main drain. I wanted to address that before I start thinking about a new pump/motor. Which by the way, needs to happen soon I'm sure. I've seen some other pics where the skimmer holes are covered by some sort of flap. Should I have one of those?
Correct, the Jandy controls the flow for the cleaner, the skimmer, and I would assume the main drain. I've played with it in every which way but cannot get any flow from the main drain. Is the second hole in skimmer connected to the main drain? Thanks so much for your input.
The MD is normally connected to a skimmer hole. Do you have a vac plate for the skimmer? Either way, take something and that fits pretty well and lay it on top of the skimmer basket. If the second hole is to the MD, and it's not plugged, it'll start sucking pretty good. Keep an eye on the pump strainer to make sure it doesn't run dry when trying this.
