Results 1 to 12 of 12
Thread: Sans pool build, oh the bids, oh the gear, oh the humanity
    Nov 2007
    Atlanta, GA
    5
    Hello all,
    I've been lurking for a while and decided to go for broke. I'm a complete pool novice so dumbing it down for me would be much appreciated.
    We're getting bids on an in-ground, Pebble-Tec, ~90 ft+ perimeter lagoon shaped pool with an elevated spa; salt system. We have three little kids; we'll be using this pool a lot I suspect. I've built the attached spread sheet trying to apples-to-apples compare the bids, recognizing that my bid information is somewhat incomplete.
    What I'm trying to get to are the following:
    1) Are there any glaring errors here - something not up to snuff, cheap cop-out, silly?
    2) Heyward vs Pentair vs Jandy - everyone has an opinion, trying to the best stuff that lasts the longest.
    3) Is the equipment proper (HP, BTU, quantity, etc)
    4) How many return lines should this size pool have? (bids have ranged 2 to 8 )
    5) What am I missing?
    I'm not asking for a "pick column B" answer. I'm trying to educate myself and compare these bids.
    Column A is a "National Builder" that I will more than likely NOT use as theirs is the only bid w/o PebbleTec . I include them for reference only. Columns B, C and D are all well respected local co's with good histories.
    You can ignore the "final prices" row at the bottom, decking and pool size is pushing the numbers around a lot. Blank spots just means they didn't specify the answer in their proposal - this information should be easy to get and in some instances can probably be inferred from other bids.
    Thank you very much in advance, this board is great.
    Sans
    Attached Files Attached Files
    14K Gallon IG Diamond Brite Finish
    24SF DE Filter
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    It looks like the first column is the National Builder, "Blue Haven" since they call everything, "smart" this and "smart" that. I think the "smart" thing to do is stay away from Blue Haven. Of all the builders we met with, Blue Haven had the sleaziest salesperson who outright lied about equipment facts during his sales pitch. Based on other reviews I've read, I would stay away.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Nov 2007
    Atlanta, GA
    5
    Thanks Sean, will do. The "Smart" column was a veiled attempt at not mentioning any names, you know, to protect the innocent.
    Sans
    24SF DE Filter
    Sep 2007
    Midwest
    330
    An absolute pool newbie myself but just finished our build.
    Have you considered pebble "sheen"? Its made by pebble tec but is alittle easier on the feet. Many are quite happy with tec vs. sheen so it really comes down to personal preference.
    Dave
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
    SeanB's Avatar
    Mar 2007
    2,622
    Quote Originally Posted by Sans Pool
    Sans
    Generally I agree and try not to single any companies out as no one is perfect, neither the builders nor the customers. However, BH has developed quite a reputation and I figure there are probably a fair number of people who will visit the site during their research. Certainly BH is capable of building a quality pool, and I'm sure there are many out there, but their sales tactics can be pretty deceptive, as I saw firsthand. Anyone considering them should do their homework and use caution. jmo.
    Please keep us posted on your project. It looks like your going to be buidling quite a pool!
    Sean
    TFP Founder
    Nov 2007
    Atlanta, GA
    5
    Thanks dlsdo,
    I am considering sheen as well. Sounds like $3/per square foot extra bringing the Tec coating from $8.15 to $11.15 sq/ft (as far as builder 'B' was concerned). So, about $2K extra all in. I'll have to feel the difference to see if its worth it to me.
    Interestingly, it makes me notice that B is charging $900 flat to PebbleTec the spa. Divided by $8.15 that suggests a square footage of over 110 feet. I would think a 7' circular spa would be closer to 40 sq ft....sounds like a negotiating point.
    Sans
    24SF DE Filter
    Nov 2007
    Atlanta, GA
    5
    Sean,
    When I was researching BH I too found many complaints. It's tough to decipher which are location specific and which are systemic to the company. In any event, w/o PebbleTec as an option I feel good leaving them off the final bid.
    And thanks again for the input. Any thoughts on the equipment of the other guys? Anything particularly problem prone?
    Sans
    24SF DE Filter
    Jul 2007
    Suwanee, GA
    528
    My pool is very similar to 'C' and so far I'm happy with the equipment. During the build I though that I'd need more than two returns, but the pressure out of the returns is great and it moves the water very well. I don't have a spa and do not regret it one bit.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Sans
    Don't forget to add for the vertical surfaces, and not just use the surface area, which would only account for the horizontal surfaces...
    Sounds like a lovely pool. Cannot give any equipment advice, except stay away from the ozone/mineral sanitizer systems, though it looks like you had already decided NOT to go with column A
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Nov 2007
    Atlanta, GA
    5
    [quote=The Mermaid Queen]
    Quote Originally Posted by "Sans Pool":11383wyr
    Sans
    Sounds like a lovely pool. Cannot give any equipment advice, except stay away from the ozone/mineral sanitizer systems, though it looks like you had already decided NOT to go with column A[/quote:11383wyr]
    Good point - there are certainly more seats and other surfaces in there.
    Thanks for the advice on the ozone system - that sounded a little bit like bunk to me but I wasn't sure. He kept talking about how "ozonination is how they clean your bottle water"....I kept think, yes, along with a lot of other measures.....
    24SF DE Filter
    Rocklin, Ca
    467
    Sans Pool,
    I feel the same as Sean in regards to BH. They seem to have more than their fair share of negative things said about them. Check the local BBB. Make sure you talk to people who have had a pool built by whomever makes you short list.
    Check this site and others like poolforum.com to find out how to select a pool builder.
    Good luck and please report back on your progress. We all love hearing about and seeing new pools.
    Kevin
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Jul 2007
    Suwanee, GA
    528
    I remember the post on Garden Web about the lady who had a BH pool and they embedded the BH name and logo into one of the steps and refused to remove it stating it was in the contract. That post mysteriously disappeared from the site.
    Gary
