Thread: Wintertime pool care?
    Sep 2007
    Midwest
    329
    Do I need to add chlorine or test the water during the winter when the pool is closed?
    I live in the Midwest. It gets very cold here during the winter. My new gunite pool will be closed for the winter in about 2-3wks. This is my 1st pool.
    Dave
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
    If you have done the whole closing routine and covered the pool then there is no need to check over the winter. Some people like to check now and then when the pool isn't frozen solid but that shouldn't be necessary. If you are leaving the pool uncovered then it is worth checking now and then when it isn't frozen, though there should be little enough to do even in that case (so long as the water is cold enough).
    Sep 2007
    Midwest
    329
    Thanks Jason
    Dave
    Our pool-
