Return Flange Replacement?
Oct 5, 2007
86
Philadelphia, PA
The plastic flange on the return of my pool cracked and about 1/4 of it fell off. The pool does not seem to be leaking now. How hard is to replace the flange without the liner moving? Am I better off replacing the flange or just leaving it? What's the best way to replace it?
Thanks!
Thanks for the reply. I really hope this is easily replaced. I'm attaching a few photos of the flange and the piece which broke off.
Bama Rambler, thanks for the help. I was able to buy a new flange at the local pool store. As you said, removing the four screws and installing the new flange was easy. The liner stayed in place. The replacement took only a few minutes and went smoothly.
Thanks for the help. It's great to have someone give you the benefit of their experience.
