Re: How do i get all of this GUNK out of the bottom of my po
I suggest you get your CYA level to the recommended 30-50 range. You are wasting money on chlorine until you get the CYA right. I wouldn't worry about the other levels in your pool until you get the algae under control. You need to keep the FC at shock level constantly. Need to check FC levels hourly and add more chlorine if it's dropped below shock level. Not until the FC level drops less than 1 ppm overnight do you have the algae under control. IF you CYA level is only 10, the chlorine can burn off in less than an hour during daylight even without algae. Hope this is helpful
