I measured the chlorine level on my return water and a question came to mind. Is the actual chlorine production a constant (5 ppm in my case) for the % of normal pump run time? Is the output greater during Super Chlorination, or just 5 ppm for the entire run time? I'm assuming water temp and salt level would have some effect.
Thanks
Thanks
