Results 1 to 9 of 9
Thread: whats a good above ground spa, not sure what to call them
    Guest
    ok after a 10,000 estimate to attach an inground spillover spa in to my pool, i think im just going to buy a real one and have sit on my patio and build a deck around it. I think i might like this better because it has its own heater and pumps, and i can use it when the pool is closed, also i think the jets are better towards a massage. So can you guys reccommend a good one.
    Thanks In Advanced
    DaveNJ's Avatar
    Toms River, NJ
    520
    Don't know much about spa's. Further down in the threads I posted swim spa. I saw it after installation and it was pretty nice. Owmer is about 6'4" and swims in it all the time.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Ohio
    217
    Hi Rollin Thunder
    I have a Tiger River hot tub and I have had it 6-7 years I think. (Time is flying buy) I Had 2 problems 1.broken lift strut for the cover that I replaced myself 2.broken diverter valve that i replaced myself both things very miner. Mine is a small tub (340 Gal) but just right for our needs. I found the tub I wanted built a solid deck about 3 feet bigger then the tub at ground Level. they installed the tub on that deck then I built the other deck at the level of the step in the tub. This made it very nice to get in and out but it also will leave you with a couple of feet of tub out the top of the deck. just the right hight to sit on. I cant say about other brands but I like mine and it is holding up well. Good luck in whatever you pick out we find the hot tub to be wonderful because the pool is closed for the winter. Nothing like a hot tub at night as it is snowing.
    Good Luck
    Ric W
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    Guest
    im looking at a HOT SPRING spa, the filter system is strange but i like all the other features, a different pump for filtering so when you run the jets filtering does not suffer, really neat water feaures and the stereo. does anybody know the brand of hot tubs that has the pop up tvs and pop up speakers and gives you a 5.1 surround. I will post a pic of the area tommarrow when its day time to give every one an idea about what i want to do.
    thanks for all the input. Is a stand alone spa a good decision then one by the pool?
    Greetings--
    We had a stand alone spa at the other house. We liked it because of its self contained design-- easier to keep the water balanced, temp control and better jets.
    The down side was that one had to climb external and internal stairs to get in and out. We were occasionally a bit -- umm-- wobbley.
    We have always liked our friends' ground level one due to easy of access.
    We looked at adding an in ground one to our new house's pool-- wayyyy to costly !!
    We'll look at a new stand alone unit here once we get settled and save up some cash-- man-- a new house is a money pit eh ? LOL
    - Reji
    Guest
    Quote Originally Posted by Piney
    Greetings--
    il will say ever since we moved into this house its, lets add this, we want this, o i dont like that lets change it.
    but i want to build a deck on the left hand patio and set the spa on the ground and have top of the spa even with the floor of the deck. I have plans, just need to know whats the best spa to drop in there.
    Mar 2007
    Knippa, Texas
    289
    Hot Spring spas are good. I bought mine second-hand, it's nearly 20 years old, and it still works. I would choose a portable hot-tub over an in-ground spa b/c they're more comfortable, with shaped seats, etc.
    The filter system on my hot tub is a pain, but from what I've heard, that's been re-engineered. In mine, the filter compartment can only be accessed from inside the hot tub. So if the tub is full of water and you take out the carts to clean them, all the junk in the filter compartment floats out into the tub. Ick.
    It's not perfect, but I think it's quite a testimonial that the equipment still works great after 20 years!!
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    May 2008
    Fort Gratiot MI
    66
    Re: whats a good above ground spa, not sure what to call them
    To answer the person who asked about the pop up TV and speakers, I think it is made by Sundance. I know they have pop up speakers for a stereo on their spas.
    I also have a Sundace, it is their Optima series and is a '97 The only thing I had to fix was a plumbing leak, (I bought it that way it had leaks and I bought it for 600.00 and fixed it for about 100.00 more.I think the previous owners let it freeze thats why the 2 leaks in it) the #1-2 speed pump went out last year and I sent it in to get fixed and bought another one for cheap on ebay. Thats the only problems I have had with mine. The pump to be redone cost me about $80.00 to have it repaired.
    When I bought it from the dealer he said the same spa new in their store would be around $8000.00 so I think I got a good deal! LOL
    If you put your spa on a cement pad make sure it is thick enough to support he weight. Mine is a 450 gallon spa and I poured a 5" thick pad for it. The minimum pad thickness is 4" so if your pad is less than 4" thick Id pour a thicker pad that will hold all the weight.
    Brian
    24' round Vinyl liner Doughboy 48" deep 52" sidewall
    1hp Doughboy pump w/timer
    Doughboy Silica II filter with Zeosand
    Raypak 180,00 btu heater
    BBB method
    Sundance Optima '97 450 gal. spa w/Delzone ozonator
    Beats driving to the lake, and I'm only a block away from the lake!!
    The Sundance Maxxus Hot Tub comes with a titanium heater which is awesome for keeping the temperature even while your in the tub (we had a hot tub in our old house, model forgotten, where you would set the temperature for 102° and it would inevitably drop to 100° by the time 15 or 20 minutes had passed). Thankfully, this is not the case with the Maxxus.
    Artificial Palm Trees and NEW Palm Tree MAILBOX- http://www.xtremelytropical.com -- Get your mail delivered in the "tropics" and create your own backyard tropical oasis with your own artificial palm trees!
