Thread: Chips in fiberglass
    Mar 2007
    Knippa, Texas
    289
    Chips in fiberglass
    I've noticed a couple spots in my pool where there appears to be a small chip or hole in the fiberglass finish. There are about 3 or 4 of them. They don't seem to be leaking (tho I haven't done the dye test), but I wonder if they could/should be repaired. I've noticed a place in the bottom of the pool that appears to have been patched/repaired in some way. Would the pool have to be drained to fix these spots? One of them is near the bottom in the deepest part of the pool. Another is on a step, and there is a very small one above the water line.
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    mbar's Avatar
    Ashland PA
    257
    You can contact the manufacturer of the pool you have. My pool had a chip out if it and they came and repaired it under water - you can hardly tell where the repair is. It looked like some kind of putty. The pool manufacturer should be able to tell you how to repair it, or have someone who can repair it for you - they will at least be able to tell you what to use to repair it, but I know it can be done under water.
    16x33 fiberglass pool sand filter
    Mar 2007
    Knippa, Texas
    289
    Quote Originally Posted by mbar
    You can contact the manufacturer of the pool you have. . .
    I don't know the manufacturer. . . I don't even know if the supplier is still in business. I do have a flyer from that business so I could possibly find out something. Thanks for the input! I'm glad to hear that the repair can be done underwater.
    ~Jules~
    Taylor K-2006 test
