SURVEY QUESTIONS
Poolsean
1,421
Ft Lauderdale, Florida
Hello everyone,
Once again, I'm posting some questions for salt chlorine generator owners. Since I know there are a diverse selection of scg owners, and I know everyone has an opinion, I would love to get yours. Please know that I am not looking for solicitation for Pool Pilot, and NO SLAMMING OF PRODUCTS.
-Thanks, Sean
Which Salt Chlorine Generator (scg) do you have?
Which size cell did you select?
Why did you selection that system?
What features are most important to you?
What did you pay?
How did you purchase it (internet, PB, e-bay, etc)?
How many gallons is your pool?
What additional features would you like to see on an scg?
How did you previously sanitize your pool?
Which Salt Chlorine Generator (scg) do you have? - AutoPilot Total Control with aux relay
Which size cell did you select? - SC-60 (50,000 gallons)
Why did you selection that system? Wanted a high tech toy
What features are most important to you? PH regulation, alpha numeric display, pump control
What did you pay? $2300 + self install
How did you purchase it (internet, PB, e-bay, etc)? Internet
How many gallons is your pool? 20,000
What additional features would you like to see on an scg? remote display, FC sensor that works, pump always on mode
How did you previously sanitize your pool? Bleach
Which Salt Chlorine Generator (scg) do you have? - AutoPilot DIG220
Which size cell did you select? - SC-48
Why did you selection that system? Manifold, pump control, control features, warranty
What features are most important to you? display, pump control
What did you pay? $900+ self install
How many gallons is your pool? 21,000
What additional features would you like to see on an scg? true control of 2spd pump, coupling for sensors not srews
How did you previously sanitize your pool? SWCG installed on new pool
Which Salt Chlorine Generator (scg) do you have? Autopilot Digital DIG-220
Which size cell did you select? SC-60
Why did you selection that system? Forum comments and system features plus in a big way the support available on line for this model (PoolSean), availability from several internet sources allowing price matches, and cell manifold concept
What features are most important to you? Cell PVC manifold for cell and detectors, salt ppm readout, digital readout, reliability, power settings
What did you pay? $985.00
How many gallons is your pool? 30,000 gal
What additional features would you like to see on an scg? auto control of chlorine level, ability to bypass temp compensation
How did you previously sanitize your pool? Chlorox BBB
Aqualogic
T-15-Cell
I went with the Totally Hayward system to get a 3 year warranty
Integrated with controller and display, chlorine control, salt reading, temp reading, delayed start, self cleaning, cleaning reminder, error reporting.
What did you pay?
~$350. Incremental cell cost to the controller.
Wholesaler in the area.
21000
Automated water measurement (CL, PH, CYA, TA, CH) - jk the last three I don't think are possible.
It would be nice to be able to set the chlorine level for different water temperatures. Not just temp comp but settable temp comp.
New pool
Which Salt Chlorine Generator (scg) do you have? Jandy AquaPure
Which size cell did you select? 1400
Why did you selection that system? PB did
What did you pay? Arm and a Leg, included with pool
How did you purchase it (internet, PB, e-bay, etc)? PB
How many gallons is your pool? 21k
What additional features would you like to see on an scg? Either a chlorine sensor or I'll even settle for production percentage per day and not runtime.
How did you previously sanitize your pool? N/A
Which Salt Chlorine Generator (scg) do you have? Pentair Intellichlor
Which size cell did you select? IC-20 (up to 20,000 I think)
What did you pay? Included in pool price, unknown
How many gallons is your pool? 15,000
What additional features would you like to see on an scg? Ability to set Chlorine at a set PPM as oppose to percentage.
How did you previously sanitize your pool?[/quote] first pool
Why did you select that system? PB selection
What did you pay? came with pool
How many gallons is your pool? 11,000
What additional features would you like to see on an scg? repeating canuck: Ability to set chlorine at a set PPM as opposed to percentage. Also, any chem sensors (Ph, Cl, TA, etc) would be helpful.
How did you previously sanitize your pool? While I was dreaming (first pool)
Which Salt Chlorine Generator (scg) do you have? Jandy Aqua Pure
Which size cell did you select?1400
Why did you selection that system? Package from PB
What did you pay? approx. $1000
How many gallons is your pool? 21000 gals.
How did you previously sanitize your pool? N/A - First Pool
Goldline Turbo Cell Aqua Rote
Not sure, it goes up to 40,000 gallons though.
We, too, got the all Totally Hayward system
The controls and remote, not having to be at the box to change settings, seeing salt level
What did you pay?
$1850 with the control box that controls the pumps, auxillary pumps, heaters, lights, etc...
PB
~39,000
I would also love it to display pH and the ability to set certain ppm also instead of a %.
This is a new pool so always the SWCG
Poolsean said:
Which Salt Chlorine Generator (scg) do you have? INTEX
Which size cell did you select? THE ONLY ONE IT CAME WITH *HA
Why did you selection that system? Price, self cleaning cell, inline (wish it had more, but for that price....)
What features are most important to you? Self cleaning cell, Inline, automation (timer, etc)
What did you pay? $149
How did you purchase it (internet, PB, e-bay, etc)? Internet, Cabelas
How many gallons is your pool? 14600
What additional features would you like to see on an scg? Battery backup, to have it give exact salt levels (not a high or low, but NUMBERS)
many jugs of bleach (still used to quickly shock when needed)
Which Salt Chlorine Generator (scg) do you have? Intex
Which size cell did you select? N/A
Why did you selection that system? It was cheap.
What features are most important to you? Didn't want to deal with daily bleach handling.
What did you pay? $150
How did you purchase it (internet, PB, e-bay, etc)? Cabelas.com
How many gallons is your pool? 8500
What additional features would you like to see on an scg? More control over timer settings. Remember settings through a power loss. Compatible fittings!
How did you previously sanitize your pool? Recently converted to chlorine from Baquacil.
Why did you selection that system? Pump control, reputation
What features are most important to you? Pump Control, Digital Display
What did you pay? $850
What additional features would you like to see on an scg? PH and TA display
How did you previously sanitize your pool? Chlorine puck feeder
Which Salt Chlorine Generator (scg) do you have? Intellichlor IC40
Which size cell did you select? Selected by pb
Why did you selection that system? Selected by pb
What features are most important to you? Not having to add chlorine manually
What did you pay? Don't know Pool pricing not itemized :(
How did you purchase it (internet, PB, e-bay, etc)? pb
How many gallons is your pool? 15000
What additional features would you like to see on an scg? This may be a stupid suggestion ... or it may be a feature that's already available but I'd love to be able to set my SWCG to maintain a given FC level. Right now I find myself adjusting the output % based on so many different variables. System running time, temp, sun etc... All It' trying to do is maintain a FC level of 5.0. I figure I should be able to tell my SWCG "5.0" and it does the rest! :-D
How did you previously sanitize your pool? First Pool, SWG installed from the start.
Aqua Rite/Goldline
the one for up to 40K gallons?
The pool builder only sold Heyward
longevity
What did you pay?
about 2K off the top of my head
pool builder
18K
automatically adjust itself up or down depending on chlorine level
always had the chlorine generator
Intellichlor IC-20
IC-20 is good for 20k gallons
Wanted to stay w/ Pentair for communication/control via wireless controller
Cell longevity and self cleaning
What did you pay?
Included w/ pool build
Pool Builder
12,000
FC sensing for auto setting of level.
First pool
Which Salt Chlorine Generator (scg) do you have? AquaRite
Which size cell did you select? T-15
Why did you selection that system? PB selection
What features are most important to you? Longevity, easy cleaning, Goldline support
What did you pay? Not itemized in quote
How many gallons is your pool? 17,000
What additional features would you like to see on an scg? Ability to input an FC level, include a "dummy" pipe to be put in its place if you ever need to remove the SWCG for any period of time (I'm clueless where PVC is concerned)
How did you previously sanitize your pool? BBB, still used in winter and for shocking if necessary
Which size cell did you select? T-15 for up to 40K gal.
Why did you selection that system? Recommended by a friend who raved about it.
What features are most important to you? Water quality and no messing with chlorine tabs.
What did you pay? $650
How did you purchase it (internet, PB, e-bay, etc)? eBay
What additional features would you like to see on an scg? pH and TA automatically measured and read out.
How did you previously sanitize your pool? BioGuard 3 step.
Which Salt Chlorine Generator (scg) do you have? AutoPilot DIG220
Which size cell did you select? SC-36
Why did you selection that system? Website info, price, looks, ease of use. After 1 year I realize that AutoPilots
customer service is second to none.
What features are most important to you? Ease of use
What did you pay? $1000
How did you purchase it (internet, PB, e-bay, etc)? I could have bought it for $950 online but let my PB pick it up
and sell it to me for $1000 installed.
What additional features would you like to see on an scg? A built in Cl and Ph meter would be cool
How did you previously sanitize your pool? First pool.
