3 way valve question
Nordy-que
Active member
Apr 2, 2021
33
Florida
Couple questions, actually.
I have 3 way jandy valves to go from pool mode from spa mode. Spa is draining slightly at night into pool. If I have the valve set just right I can keep it from draining, mostly. There is no check valve.
1. Is the 3 way valve supposed to be completely watertight when off?
2. if so, can the square gate gasket be replaced (it looked a little crusty to me), or do you have to replace the entire mechanism? A search of google didn’t turn up any gaskets for me.
thanks all!
Jimrahbe
21,153
Bedford, TX
N,
it is odd that you do not have a check valve... Show us some pics of your equipment pad, showing all of your Jandy valves and where they go.
To directly answer your question.. They sell rebuild kits for Jandy valves and yes, they should hold water.
Nordy-que
Active member
Apr 2, 2021
33
Florida
N,
Thanks Jim!
Here are photos of the whole setup plus closer photos of inlet and pressure side.
It is strange that there is no check valve on the drain side. There is one on the valve going to the waterfall outlet for the spa spillover.
Jimrahbe
21,153
Bedford, TX
N,
The check valve on the spa spillover line is the one I was looking for.. It is the one that most often is the cause for spas draining back into the pool when the pump is off.
But if the spillover line also has a manual flow control valve, that can be shut off, you can eliminate the check valve as the problem by just shutting off the spillover at night as a test.
Nordy-que
Active member
Apr 2, 2021
33
Florida
N,
Ah, interesting. I think that the spillover valve is leaky, and the check valve as well, because it was off when they put the new spillover in, and it still kept feeding in a small amount of water. Sounds like I have to replace that check valve, at least, and probably the gate valve on the 3 way on the drain side.
