Do the different valves have a "meaningful" flow difference when considering a 1.5"x 2" vs. a 2"x2.5". Obviously the pipe size will impact the answer but I am just asking about the valve body itself.
For example...if you have this scenario... 2" input -> valve -> 2" out & 1.5" out
Would there be a flow impact of choosing to use a 2x2.5 so that the 2" pipes are inside and a then use a stepdown for the 1.5"
OR
Just keep it simple and use the 2x1.5 so you have the 2 "coupled and the 1.5 inside
Is it much ado about nothing or given the option, does it make a difference?
OR
