3-Port Diverter Valves - Restriction?
MN_poolguy
Active member
May 18, 2020
26
Minnesota
Hi all,
Installing a new pool and I was originally going to order Jandy valves for the equipment pad but between estimated shipping times and cost, I made a last minute decision and went with Pentair valves. Grabbed some 2 port and 3 port diverter valves. The 3-Port valves surprised me. After choosing 2 inch suction size plumbing it sure looks like the valve will restrict the flow to significantly less than normal 2" flow rates. The actual "venturi" inside the valve is more a narrowed vertical opening. Is this normal for a 3-port valve? Did some searching but couldn't find an answer anywhere...
Which valves did you get? 1 1/2 inside/2" slip outside or 2" inside/2 1/2" slip outside?
The diverter, part 9, opens up 270 degrees of the water flow...
Post pics of what you have for the diverter.
I have the 2” - 2 1/2” version... you can see a bit of what I’m talking about in that exploded diagram. Here is a pic:
getting ready to replumb and add these valves myself. Did you go with them or did you contact Pentair? Someone else posted a picture of his valve he bought from Amazon with the same concern. He said the valves look to have approximately only a 1.5" opening.
