Thread: Pebbletec and algae growth
    Jul 2007
    Florida
    64
    Parents pool got a new Pebbletec resurfacing last year, but have taken over the care/maintenance just this summer.
    Does algae have a harder time adhering to a rough uneven gravel surface? Therefore making the pool easier to clean and maintain? Common sense would think so.
    I was told that algae growth is easier on traditional flat plaster surfaces since it grows more uniformly with a better grip... making it stronger by forming layers/sheets if left unattended to.
    22,000 gal in-ground, 3-8ft
    Cartridge filter
    Pebble Tec resurfaced
    Polaris 360
    Arizona
    925
    It would be just the opposite. Algae growth is more likely to occur in rough textures because it's harder to keep clean.
    As long as you keep your chemicals in check, you should'nt have to worry, either way.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jul 2007
    Australia
    69
    Re: Pebbletec and algae growth
    Quote Originally Posted by rimshaker
    Hi,
    Its easier for algae to stick to rough
    surfaces as there is better grip for them!
    Just remember to keep your chems in the
    right ranges and use a good algaecide as
    a good insurance policy.
    Not all algae actually sticks to the walls.
    Hope this helps!
    Take Care,
    Michael Silvester
