Keep shocking if CC is 0, chem is ok, but water is cloudy?
sws1
Aug 13, 2010
55
Neptune City, NJ
Opened pool on Friday. Got all levels where they need to be, and am keeping FC at shock level. Water is still cloudy, but getting better every day.
Do I need to keep at shock level until the sand filter clears everything up? Or am I to lower FC to normal levels now the CC is at 0?
I think it's the former, but just checking.
(I still need to vacuum some sludge off bottom and sides.)
My details:
25k inground, vinyl pool.
CYA 50
Ph 7.4
TA 110-ish
CH 220
Used CalHypo to shock until CH was above 200, now using 12.5% liquid chlorine.
Sand filter
Re: Keep shocking if CC is 0, chem is ok, but water is cloud
3 criteria to stop shock
1- hold FC overnight (<1 ppm drop)
2- <.5 CC
3- water is clear
You should hold shock until water is clear- with CYA in the pool, it shouldn't be hard to maintain
You can add alittle DE to the sand filter to help clear the pool...
