First we need to know if you have a DE filter like frustratedpoolmom asked. There are reasons to have it when you don't have a DE filter. But, on the assumption you do, when you backwash a DE filter, all the DE goes out the waste port with the water. When you switch it back to filter, you have to recharge it with more DE based on the model filter you have.
If you haven't started reading it yet, you'll find a lot of useful information in Pool School (big button at the top right of the page.) Feel free to continue to post your questions. For most people it takes a combination of reading pool school and asking questions to get the hang of it.
-- Pete
precator said:
loughps said:
The BBB equivalent for DE is DE. :) You can keep that and add it to your DE filter as you backwash and need to.
-- Pete
When do I know if I have to add the DE?
You only add DE after you backwash or teardown & clean your filter.
Diatomaceous earth particles are like microscopic sponges. It coats a fabric grid and the water goes through these tiny passages and all the pollen, dust, dead skin, algae carasses, etc get filtered out.
Typically, when the filter is freshly cleaned, you look at the pressure gauge. That is your baseline. When the gauge goes up 10 psi from that, it's time to backwash. If you notice the pool is looking cloudy and the water coming out the returns doesn't look as strong as it used it, that's another sign it's time to backwash.
I took my filter apart a few months ago just to have a look at the grids and physically clean them so I would know the baseline pressure for my filter. I had no idea how long it had been uncleaned, as I only moved in about a year and a half ago. Now I know, and there's a mark on the gauge.
Much closer. The FNS Plus comes in several different sizes. The 24 takes 2.4 lbs of DE. The 36 takes 3.6 lbs of DE. The 48 takes 4.8 lbs of DE. And the 60 takes 6 lbs of DE. All of those numbers are for a full recharge after the unit has been throughly cleaned. After a backwash you should use about 80% of that quantity.
