Thread: lowering PH with out lowing TA
    I'm new to a pool ownership . Currently I am trying to lower PH without lowering TA.
    Currently my readings are:
    PH 7.8
    TA 70
    CYN 70
    FC 5
    CH 230
    TDS 1100
    When I add acid to the pool I end up lowering my TA to about 40-60 and my PH to 7.4. Then I add Sodium Bicarb to raise the TA to about 100 and up goes my PH. When I add sodium bicarb it raises my TA along with my PH. How can I maintain my PH at 7.2 -7.4 and my TA at 80 - 120 ?
    27x52 Round Opera Prestige (SunSports) AGP - w/hopper deep end (Wilbar insrt.)
    1.5 HP Sta-Rite pump w/21" Premium Sand Filter w/Main Drain installed - ~25,000 gal
    When you lower PH, TA will always go down. There isn't any way around that. But when you add baking soda TA should go up much more quickly than PH, so that when you add acid to bring the PH back down you should have gained some ground on TA.
    Houston, Texas, USA
    148
    Re: lowering PH with out lowing TA
    Quote Originally Posted by jlee1414
    PH 7.8
    TA 70
    CYN 70
    FC 5
    CH 230
    TDS 1100
    That's odd. Sodium bicarbonate should raise the TA by 30 points, while raising the pH by just .1. Are you sure you are using sodium bicarbonate, and not soda ash or something else?
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Mar 2007
    San Rafael, CA USA
    12,082
    For practical purposes, this is correct, but in commercial pools one can add carbon dioxide to the water to lower the pH with no change in TA. It's the exact opposite of outgassing. Over time, these pools do tend to rise in TA due to evaporation and replacement with fill water that contains some TA unless they have a lot of splash-out or backwash and fill water that is lower in TA than the pool.
