Vermiculite question
Apr 7, 2011
15
Hi Guys, im new to this forum and wanted to say thanks to everyone. I recently took on the task of installing my own pool and this site has helped me greatly! I have run into a problem im hoping i can get some feedback on....
My pool excavator over dug my pool a good bit. My corners were basically hanging over air and I have some of my walls up on blocks. I poured concrete under the corners so thats good now and I'm going to pour gravel on the bottom to fill up the overdig and Vermiculite over that. One thing im wondering about is whether vermiculite will bond to concrete. I know you cant bond concrete to concrete withut a primer but can you do it with Vermiculite to concrete?
Also on my walls, they are dug out about 1 ft too much on either side. I can either try to build the walls up with concrete and vermiculite over that or just leave them as they are and let my liner stretch to fill it. I know this may shorten my liner life by a year or two but I already ordered the liner and have it. The company I ordered my kit from said that the liner will actually stretch to fill in this overdig and to just order a correct fitting liner next time. I hope I explaned that correct......
Basically my liner is designed for a hopper thats 10x6 but my walls are more like 12x6 with the overdig.
Thanks guys
ive never seen vermiculite before so maybe "bond" isnt a good term....I guess i just want to know if its ok to put vermiculite on top of the concrete and will it stick to concrete. Thanks
If I am following correctly, the vermiculite should be fine even if it doesn't develop a true bond. You are basically putting the vermiculite into a bowl, so there isn't any where it could go even if it doesn't fully bond.
Liners will stretch quite a bit, but stretching them that much often leads to minor problems latter on. I would fill things in at least part way if that is at all practical.
I cant think of a way to fill the side walls in that well. They are basically at a 3ft slope instead of a 4ft slope. any ideas? if i concrete the walls will it still be ok to put vermiculite on top of it then? Thanks for your help guys
I think it would be ok to put vermiculite on concrete. It will stay in place long enough to get your liner in and filled up with water. You could also mix some portland with the excavated fill dirt and build your wall out instead of using concrete.
Hey all.
bb2, welcome to TFP!!
Vermiculite doesn't 'bond' to anything. As Jason pointed out, it fits into the 'bowl' of you pool. If you leave voids or places where the substructure (dirt, sand, gravel, etc.) washes out, the vermiculite will crumble and drop into the void :(
bb2, even though you're getting your verm for $12/ bag, that's a lot of mixes to make up the difference in your wall, and, you add 1/2 bag of cement to each bag @ ~ $8/ bag, so you're talking $16 per mix and you'll need at least 20 extra mixes to fill that void :shock:
I'd suggest filling the voids as best you can with #57 stone, you won't be able to completely fill them to within 2" of the finished floor, but it should get you closer and save you $. You can go with concrete or sand and cement to fill the voids, but gravel lets water flow beneath the verm - water passing through the verm will wash out the cement, after a while, and leave you with 'mushy' areas. If you have any bad/ unworkable mixes of the vermiculite, use that material to fill the voids.
You might be able to 'cheat' the slopes ~ 1" on both sides and still have a viable liner, but I wouldn't go any further! My best advice is to fill the sides to match what the liner was cut to.
p.s. if you haven't seen it, there's a series on DIY IG liner pools in the "Further Reading" section of "Pool School"
