Plaster stains
May 9, 2010
20
I have several stains on my plaster. They come and go but really have been there for about 6 months or so.
I checked the forum and tried the vitamin c and trichlor test.
Both did not lighten the stain.
They become lighter during sunny day and more prominent earlier or later in day.
I do have an oak tree near the pool however I never let any leaves or other drift stay in pool very long.
I should also note that my PH did get above 8.0 on couple of occasions when I was out of town.
So, not sure if I should begin shock treatment or absorbic acid treatment?
Here are my numbers;
FC 8
PH 7.7
TA 110
CH 320
CYA 40
Here are a few pics.
Thanks for any help.
I think you may be dealing with tannin stains. AA won't help. What did you do with the trichlor, when you tested with it? If you can give a bit more detail on how you tried it out, maybe we can suggest your next steps.
I get those from my wax myrtles dropping crud into the pool. Run your FC at 1 or 2 ppm higher than you usually do and the stains will be gone in no time.
I placed tricolor puck on top of stain for 45 minutes.
Same for vitamin c tablets.
I do have an oak tree nearby but acorns never stay in pool.
I always get them out.
By the way I have been running FC around 5-9 for month now.
Doing nothing to stains.
Might mention that ph got over 8 couple of times when I was out of town.
What is tannin stain????
I'm inclined to agree with Scott. I was asking about the vit c because if it was copper the stain might get darker.
I would go ahead and try to keep the chlorine slightly elevated by 2-3 ppm more than normal and then see if they begin to fade.
Thanks for the info.
They do fade big time during the day and more prominent during dusk.
Should I use pool calculator to find shock limit and keep C that high??
I am at 9 right now and will keep it that high, brush and keep going.
Should I use any type algae treatment now?
Since with BBB I have not used any algae treatment for around a year.
