I have another question about pebble tec
The PebbleTec could be covered over, though it will be tricky to get a good enough bond. To get that bond to work the current surface needs to be carefully cleaned, you will need to use a bonding agent, and the new layer has to have some thickness so it doesn't just flake off. Chipping out and then applying plaster would be more reliable.
