Results 1 to 7 of 7
Thread: Another Refugee from Poolforum.com
    Sep 2007
    Central NJ
    63
    Hi All,
    Traffic @poolforum.com seems to be really way down low.
    Glad to see TFP is alive and well. BBB rules, so it is good to see someone carrying the flag!
    I joined as a lifetime supporter -- worth $20 to help keep the site running. Sent Ben more than that about 2-3 years ago when he was in deep do-do.....didn't even get a thank you message. Whatever his problems/issues I wish him well.
    SteveK
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Steve,
    Welcome to TFP. Glad you joined us and "Thank You" for the contribution. Sean B. has truly done a great service by getting this site up and running so quickly and with such a great group of people. We look forward to sharing your thoughts and those of others. Again, welcome.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the site SteveK. Hope you enjoy it as much as the rest of us do. Lots of refugees here.
    Joyce
    You're done SLAMing when:
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Wecome to TFP!
    Thanks for the support Steve, glad you found us and are enjoying the site.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Welcome to TFP! This site was started by and still is run (mostly) by PF refugees! That's where I learned all I know about BBB!
    If you grill, make sure you check out TFP's sister site... Grill with Skill Many of us are also over there, though some of us should stick to pool advice, and not even try to give any bbq help, like ME!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Sep 2007
    Central NJ
    63
    Thanks for the welcome, everybody!
    I've really done very little with the pool this summer (including very little use) since my wife and I have been busy building a new deck. The deck is almost done (just the railings, lighting, and one set of stairs to go). Just in time to close the pool! I didn't even install the SWG that I bought back in February. My 11 season-old Jacuzzi 27-inch sand filter sprung a leak about 3 weeks ago (right at the top). So the pump was shutdown for about 2 weeks until we found 'the right stuff' to close the leak (and keep it closed). Ended up using some fast-cure marine epoxy from Home Depot (used it inside and out).
    The I was faced with a pit filled with 30,000 gallons of green smelly water. 3-4 days @20-25ppm of chlorine (clorox on sale this week at kmart) and the pool is now clear again. Hopefully it will stay near 80 degrees and can be used a few more time before shutdown.
    SteveK
    Arizona
    925
    Hi and welcome to the group.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
