Results 1 to 10 of 10
Thread: Leaf Net question
    Richardson, TX
    287
    Leaf Net question
    I'm wondering if anyone here uses one of those leaf nets without a winter cover? With fall coming up I am thinking of trying one of these to help me with leaf maintenance...
    I'm in N. Texas where most people I know don't actually 'close' their pools but we have a bunch of trees over the pool and was thinking this might be a nice option.
    And for the record, there are no kids, no outdoor pets and the fences are locked so I'm not worried about a safety issue.
    Thanks!
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    We have purchased one and are going to use it for the first time this year. Last year we had a nasty mess when we took off our other pool cover. We have lots of trees around our pool as well. Cant wait to see what the diiference is !
    I have read on here that you should empty the leaf net a few times during the "leaf dropping season" so that they dont sit in the water on cause trouble in the spring time.
    Good Luck with yours!
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Richardson, TX
    287
    any other opinions before I either suck it up and buy it or suck it up and accept a fall of cleaning leaves out of the pool?
    Anyone?
    Butterfly's Avatar
    South Carolina
    10,045
    Well, FWIW, last winter we just did maintenance. Dipped leaves. Once the main drop was over, it took about ten minutes every other day or so to maintain a beautiful clean open beautiful-to-look-at pool. Really nice with the fire pit going. We have tons of huge trees, well, all our neighbors do. Start up was a breeze as the water warmed, the pool only needed tweeked and vacuuming. btw, we actually did vacuum once last winter. Good luck with your decision.
    Joyce
    You're done SLAMing when:
    DaveNJ's Avatar
    Toms River, NJ
    520
    I bought one early this year. Intended to use it for helicopter seed pods, Mapple tree. This year there where no seed pods (strange). Going to use it when the leaves fall, then remove it before freeze.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    We purchased ours because we have alot of trees around our pool. Oak, Pine and a few Dog Wood so you can imagine what our leaf situation is like. In the fall the Oak trees drop leaves and in the spring they drop leaves and in the spring they drop a "worm" like thing that fills the skimmer basket real fast! Last year (winter) I had planned to take some of them down that were right beside the pool to remidy the situation but it didnt happen ... this year it will !
    Joyce , what kind of maint do you do? Do you actually do a winter "shock" and algea treatment or do you actually maintian your chems all winter long?
    Les
    Helpful Links:
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by TizMe
    Tiz, Last winter we did not do a winter shock nor an algae treatment, but maintained chemicals until water temp fell between 55 & 60 degrees. The only maintenance we did last winter was scoop leaves and vacuum once, right after the majority of leaves had fallen. To average it out our winter maintenance was about ten minutes every other day or so. That was it. And trees........ they are huge and in close proximity to OUR pool.. This winter, however, we will actually test our water for possible pH issues because of the new-ish plaster. Hope this helps. Joyce
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Sure does help Joyce. Thank you .... the trees will still come down though. A majority of them are Oak trees and they have a wormy kinda thing in the spring which makes it a pain the others are Pine trees.
    So to sum it up ...dont close the pool,check chems until water temp gets to be 50-60 degrees then we can stop until spring time. Going to run the pump at night for v4 or 5 hours .... will that be enough?
    Les
    Helpful Links:
    Jul 2007
    Northern NJ
    299
    Quote Originally Posted by DaveNJ
    I bought one too this year for just the same reason! I must have gotten your helicopter seed pods because they have been the bain of my existence all summer! They have stained the pool, pavers, shed, furniture. Everything. Good luck with yours.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Tiz,
    I can only tell you what WE did last winter and will do again this winter. Our pool is IG and yours is AG and there may be huge differences in what can be done. Also, our pool is somewhat protected because of the terracing of our yard. So please verify everything with AG folks in your area/location (or those here that know!) what you should or should not do. To sum it up, this is what we did:
    1. Maintained chems until water temp dropped below 60 degrees,
    2. covered our pool equipment with a heavy blanket and a tarp so that nothing was exposed to the elements,
    3. dipped leaves using leaf net w/10 ft. pole
    4. did not run pump except for the one time we vacuumed.
    Hope this helps.
    Joyce
