Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Pool Surrounds and Weeds
    Mar 2007
    Richmond, Va
    182
    Okay you above ground poolers - how do you keep those pesky weeds from growing up around everything.
    I'll do a picture soon, when the weeding is done! but basically we have placed weed barrier around the pool, filled that with river rock and placed pieces of slate around this following the circle of the pool. You'd think that would stop the weeds but it does not completely eliminate them. WE can't use Round UP because of the grass eating schnauzer.....
    Aside from spending hours plucking each weed and grass blade, are there any dog friendly compounds we could use to eliminate the weeds?
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    Either spray the weeds with vinegar, or pour a little salt on them. Voila! Dead weeds.
    Be careful with the salt method if you are near other grass, as it will spread with water/rain and kill it too!
    I'd still watch the pooch, but these are both non-toxic, and will wash away with water once they do their job!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    Richmond, Va
    182
    Wonderful, thank you!
    If you use the vinegar, given the acid base of it, will it harm the pool liner at all if it seeps underneath. Some weeds are very close to the pool structure.
    Mar 2007
    Morris, IL
    477
    You can use vinegar as was stated, pour directly on the crown of the weed, or Boiling Water directly on the crown of the weed. What I did around my pool was spread mulch, and plant plants. Plus I pull weeds occasionally. Just regular yard maintenance.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    i plan on eventually laying a border and 3-4' of landscape fabric, then filling with rocks/gravel & maybe some shrubbery.
    Dave
    In-ground PebbleTec 11,000 gallons (installed 1997)
    Pentair Cartridge Filter System w/2HP Pump
    Paramount In-Floor Cleaning System
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    weeds
    We put down such a thick layer of hardpack Class 5 with gravel over the top of that and a concrete border around it. So far only the toughest of weeds want to come up through it - dandelions and some quackgrass - there aren't a lot but we just pull those.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    I'd use Roundup. The little bit your dog might consume won't have harmful effects according to this study: http://www.mass.gov/agr/pesticides/righ ... te2005.pdf
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Waterbug,
    I also have a grass eating dog. I do not have an AG pool but I do have pool equipment susceptible to the same problem. I dug out the roots of grass/ weeds in question, sprayed the entire area with Round Up, layed down a double layer of landscaping fabric and then put in 4" of Limestone Rock. I will get a pic posted sometime this weekend. I have not seen weed one since doing this in January of this year.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    divnkd101's Avatar
    Mar 2007
    587
    Waterbug,
    I have been meaning to get these uploaded. Sorry it took so long.
    MIKE
    DONNIE's Avatar
    Mar 2007
    OKLAHOMA
    122
    Read your round-up bottle. Once dry it is not harmful to pets.
    8500 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    Mar 2007
    Richmond, Va
    182
    Thanks for all the tips. Will try some out this weekend, and will read the back of the roundup bottle - duh???? Can't read anything that small without my glasses these days!
    Also a friend from Canada sent Canadian Living's version of Weedzapper, which is a combo of 2 tbsp. dish detergent, 4 cups vinegar and 1/4 cup salt.
    We'll try that one too.
    I used the black plastic edging, and the winter cover that came with my pool as the groundsheet onto which I piled round 3/4" stone, haven't had any grass issues since (2+ years in some areas).
    Jun 2007
    Richmond, Virginia
    2
    Oh, come on now. Pulling a few weeds is good exercise!!!
    Karen
    18' x 4' AG Vinyl liner
    Waterway 100lb sand filter with 1 1/2 hp pump
    Middle TN
    Mar 2007
    Coastalish 'down easter'
    4,160
    Waterbug, when I did AG pools (seems like a lifetime ago ) we always had ~ 1' of gravel (color/ type you're option) around the bottom of the pool (1' out from the side and 4" at the pool tapering to 1- 2" at the lawn side). I was informed that this was recomended. You can put weed block under it or just plastic trashbags to keep the weeds from growing Hope you're enjoying the pool! and the warm Richmond summer!
    Luv& Luk
    -Ted
    weed control
    My pool came with a 35 foot diameter black tarp winter cover, since I don't use it for numerous reasons such as no real leaves to speak of, very high winds that just lift it, more work that it's worth etc etc...it became the free "landscape fabric" under the pea gravel around my pool.
    I put the 5" black edging in to stop the grass from emcroaching and the gravel from falling onto the grass, tucked the black tarp around the edging before bacfilling and packing it, then laid the tarp back towards the pool, trimmed and folded it as required, used 6" rigid wire bent into an L to hold the tarp/fabric on place and spread pea gravel all over it.
    The pictures were taken last week, the area to the left and right of the steps is now 4 years old and I have not pulled ONE weed.
    The area where the solar panels are is 3 years old - also not one weed, the area at the rear under the reel is 2 years old and no weeds either.
    Even though the pea gravel is round, it still hurts little feet when the kids go to get into the pool toy boxes, so my wife placed decorative pavers in key locations.
    This is about as "no maintenance" as it gets unless you pour concrete, and there's no edging since even the riding mower easily negotiates every bend.
    Mar 2007
    Richmond, Va
    182
    Waste: That warm Richmond weather has been great! We have a friend visiting from my native Canada, weed problem solved -= she has been pulling them all while we are at work! Now we have a clean slate so to speak and I can keep it clean with the weed zapper or round up stuff....and yes, pulling the occasional weed for that exercise!
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    Here is my grass & weed removal system
    :P :P
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    The only problem I see with that is an accidental tusk through the pool wall!!! OOPS
    259
    Quote Originally Posted by matt4x4
    They are pretty blunt because he has broken them a couple of times although they still hurt when he jabs them into your leg
    Confer E9120 Steps
  20. Back To Top    #20
    Sep 2007
    California
    13
    Use a pre-emergent...
    Even with a weed barrier and rock eventually enough stuff will blow in on top to give the weeds a chance to survive. Most people won't tell you that a weed barrier won't really stop weeds. What they do is stop the weeds seeds already in the ground from getting all the things they need to germinate and help keep new weed seeds that get blown/dropped in from getting a good hold in the ground to make weeding easier.
    That is a good start but using a good pre-emergent at least twice per year will drastically reduce the number of weeds. Since you are concerned about animals what I do is one of two things:
    1. If it is a dry year I will water the ground where the pre-emergent is going to go with a solution of dish soap and water. About 1 cup of dish soap in a 20 gallon hose end sprayer topped with water. The soap helps wash off dust etc. that causes the water to sit on the surface of the ground. Next I spread the pre-emergent at the recommened rate then I do another watering with the 20 gallon hose end sprayer this time with a half a cup of dish soap. This time the dish soap is used to break down the coating on the pre-emergent so it will get into the ground away from any animals.
    2. If it looks like a wet year I will wait until after the first good rain when the ground is evenly wet then I will apply the pre-emergent just before the next storm and let mother nature do all the work.
    After that a good layer of mulch and a couple minutes a week you should be well on top of any new weed growth.
    Remember do not apply it anywhere you plan to plant seeds as the pre-emergent inhibits the ability of seeds to germinate. It will not however hurt existing plants or cause any problems with the planting of live plants.
    Hope this helps,
    Jeff
    Finally built! 30 x 29 inground gunite w attached hot tub, diving rock and spring.
    Color - Satin Matrix Midnight Sea
    Perimeter 90 ft, depth 4.5 to 8.5
    water surface area 569
    Jandy 580 2HP Stealth
    400k Laar LT heater
    280 Polaris
    Aquapure 1400 SWCG
    PDA PS8
