Results 1 to 7 of 7
Thread: questions on Borates
    Aug 2007
    Pensacola
    129
    I've searched the forum on this but I still don't understand completely the importance or function of borates in the pool? Is this something that is absoultely necessary? What is the benefit of a good level of Borates in the pool?
    24' AGP vinyl, 3/4hp Pentair 2-speed, Pentair Quad DE 60
    Pool Rover Jr.
    TF-100
    No, there is no great need for borates in your pool. I think of borates as an advanced technique, ie not for everyone.
    Borates help reduce the rate of PH rise, improve the water feel, fight algae, reduce chlorine usage, and add sparkle. Recommended levels if you want to use borates are between 30 and 50 ppm. Adding borates up to that level can be kind of a pain and there is a small risk to pets which reguarly drink large amounts of pool water. You can use my Pool Calculator, see the link in my signature, to calculate the amount of borax and acid needed to raise the borate level.
    Aug 2007
    Pensacola
    129
    Man, Jason, You are quick We do have a labrador that I let swim maybe once a week and he does sometimes swallow pool water while swimming. Do you think I should avoid borates because of that? He otherwise has no access to the pool and never drinks the pool water intenionally.
    Pool Rover Jr.
    TF-100
    Occasional sips of pool water with borates won't be a problem for pets. It is only if they are drinking large quantities of pool water nearly every day, ie if it is a primary water source.
    Spring Hill, Florida
    40
    The cat who lets us live here and use her pool drinks from the pool at least once a day. Not large quantities, just sips (its a saltwater pool!) It hasn't seemed to bother her a bit.
    If I had an animal that drank large quantities from the pool, I'd try keeping a bowl of fresh water out there in the hope that it would be a prefered source.
    I keep the borate level at 50 ppm.
    Mar 2007
    Knippa, Texas
    289
    If you have borates, you can keep a lower TA, is that right? If so, how much lower?
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Assuming CYA is 30-50, TA around 50 seems to work well enough with borates. I imagine you could go a bit lower if you really wanted to.
