Unstabilized chlorine vs. stabilized chlorine used to SHOCK
Aug 29, 2007
11
San Diego
What is unstabilized chlorine vs. stabilized chlorine?
SHOCK -- This is the process of raising your FC high enough to break down the CC that has formed, sometimes called breakpoint chlorination ("shock" is a verb, not a noun! It is something you do to your pool, not a special product that you use. Any unstabilized chlorine is suitable to use in shocking
Thanks!!
Liquid chlorine is also called bleach (common household bleach, avoid scented versions). In some areas pool stores sell it in 10% or 12.5% concentrations, in other areas they don't and it is simpler to buy regular bleach at a discount store.
Stabalized chlorine contains CYA, unstabalized doesn't. Using chlorine with CYA in it can be problematic because the CYA eventually builds up to high levels and causes problems.
