Thread: Unstabilized chlorine vs. stabilized chlorine used to SHOCK
    Aug 2007
    San Diego
    11
    What is unstabilized chlorine vs. stabilized chlorine?
    SHOCK -- This is the process of raising your FC high enough to break down the CC that has formed, sometimes called breakpoint chlorination ("shock" is a verb, not a noun! It is something you do to your pool, not a special product that you use. Any unstabilized chlorine is suitable to use in shocking
    Thanks!!
    cbisquit
    Aug 2007
    San Diego
    11
    I think I may have answered my own question....does sodium hypochlorite sound right? If so, is there a shorter name the pool store would use?
    Thanks again!!
    cbisquit
    Liquid chlorine is also called bleach (common household bleach, avoid scented versions). In some areas pool stores sell it in 10% or 12.5% concentrations, in other areas they don't and it is simpler to buy regular bleach at a discount store.
    Stabalized chlorine contains CYA, unstabalized doesn't. Using chlorine with CYA in it can be problematic because the CYA eventually builds up to high levels and causes problems.
