Thread: Low Alkalinity
    sammm's Avatar
    North Richland Hills, TX
    257
    Low Alkalinity
    I just tested my water. Everything is 'normal', except my alkalinity seems low (60). PH is ~7.4. I only use bleach and have to add acid occasionally to bring the PH down (normal, right?).
    Is an alk of 60 too low? I've added baking soda in the past and got it up around 80 or 90, but it slid back down. Should I care? TIA!
    PS
    Water looks great and is crystal clear.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Mar 2007
    San Rafael, CA USA
    12,082
    A low TA is actually not a problem and will help reduce the amount of acid you need to add to keep the pH where you want it. The only issue is that it reduces the saturation of calcium carbonate in the pool, but that only matters if you have a plaster/gunite or similarly surfaced pool (or any exposed grout with tile). For a vinyl pool, for example, it doesn't matter. For fiberglass, you should have some Calcium Hardness (CH), but don't need to be at full saturation (we think). If you have a plaster pool, then it's easy to compensate for the saturation through a slightly higher pH target and/or a higher CH level.
    If your CYA level is low (say, around 30 ppm), then I wouldn't worry about the TA until it gets to 50 ppm. I would still keep it above that, but you should find that it drops rather slowly over time. And just be careful about adding any acid to the pool -- it will take less to move the pH due to the lower TA (and that includes acidic sources of chlorine such as Trichlor and Dichlor as well as non-chlorine shock).
    By the way, do you have water aeration features such as a waterfall, spillover, fountain, air jets, etc.? Or do you get a lot of summer rains (raindrops splashing cause aeration)? Pools are intentionally over-carbonated, just like a carbonated beverage (though obviously not THAT carbonated!) so outgas carbon dioxide to the air and that process causes the pH to rise (with no change in TA). Then, adding acid to lower pH also lowers the TA. You may also find that having a pH target of between 7.5 and 7.7 will help compared to trying to maintain 7.4.
    Richard
    sammm's Avatar
    257
    Thanks as always Richard for a great explanation! 8)
    We do have a water fall, but I usually have it off. I have it turned off most of the time because my system only has 1 pump and it 'takes away' from my Polaris. We did have an extra wet summer this year in the DFW area as well. My CYA was ~40 last time I checked it, so that makes sense too. I'll just go with a slightly higher PH and move on. Thanks again!
    matj6876's Avatar
    Jul 2007
    DFW, TX
    105
    Sammm - just for peace of mind. I'm in the DFW area too, have similar numbers and a low TA.
    It don't help you much but at least you know you're not alone!
    My Pool: 27K gal IG plaster, IntelliFlo i1 pump, Pentair FNS Plus DE Filter, Intellichlor IC40 SWCG, Polaris 3900 Pressure Side Cleaner
    sammm's Avatar
    257
    Quote Originally Posted by matj6876
    Thanks! I'm in North Richland Hills. Where in the metromess are you?
    matj6876's Avatar
    Jul 2007
    DFW, TX
    105
    Out in the boonies.... Argyle, just North of Flower Mound.
