Thread: Salty Slip-up
    matj6876's Avatar
    Jul 2007
    DFW, TX
    105
    Salty Slip-up
    I made a bit of a mathamalogical error in my salt/bags/weight/volume calculation and as opposed to topping my salt levels off at 3500ppm I nuked it to 4400ppm
    I know it will gradually come back down on it's own but what damage am I doing in the mean time?
    FC 5.5
    CC 0
    Ph 7.5
    TA 90
    CH 320
    CYA 50
    Cheers
    My Pool: 27K gal IG plaster, IntelliFlo i1 pump, Pentair FNS Plus DE Filter, Intellichlor IC40 SWCG, Polaris 3900 Pressure Side Cleaner
    New Brunswick Canada
    819
    Mat....fairly certain your SWG can handle that concentration, its not really brutal. Some backwashing will bring it down a bit, refill then backwash again.
    matj6876's Avatar
    Jul 2007
    DFW, TX
    105
    Thanks pooladdict - My SWCG is humming along beautifully, in fact it was working so well that it was my rocketing FC that prompted me to test the salt level.
    I was concerned that the high salt level would start to rust/corrode small children or more important things like heater coils... etc...
    Guest
    Salt level should not be a problem. In fact, there are several SWGs on the market that normally operate in the 5000-6000 ppm range for salt. Above 6000 ppm corrosion becomes more of an issue.
    matj6876's Avatar
    Jul 2007
    DFW, TX
    105
    Thanks! Rusty kids would get me in the bad book with the missus!
