samt
0
uloset said:I also have a mesh cover and am following a similar process as mentioned above. Our yard has many trees and I would spend an hour every night taking out leaves, so I just throw the cover on in early/mid Sept. Instead of pucks I still use liquid chlorine and just detach a few of the anchors which gives me enough room to add the chlorine via a 2.5 quart pitcher in front of the returns. I run the filter everyone few days just to circulate things or whenever I add chlorine. I have an older loop lock or that's at least what the original owners paper works states, either way lots of light gets through it. Even with it being far from total light blocking my chlorine use around this time of year is less that 1ppm per day. Though the pucks also sound like a good solution, a few will last a long time and the small amount of CYA added will most likely be negated by the water that you remove open totally closing the pool.
On a side note I've had an idea to just rig up a short length of pvc with a 90 degree fitting and a funnel and just shove it under the cover near the the deep end return. This way you would not even need to touch the cover just pour the chlorine into the pipe with the pump running and that's that. I've just been to lazy to actually glue the pvc together.
Smart Idea with the pvc, even using pucks for a month until I remove the pump. The following year I need to add CYA , I run the pump 2 hrs a day but once my supply of pucks are gone I will do something like your doing or just poor it in the skimmer when the pump is running.
