Thread: HTML in signature
    Aug 2007
    Denton, TX
    48
    HTML in signature
    Sean,
    Forgive my forum newbness, but how can I add html to my signature?
    I'd like to do what some other folks do and make the "become a supporter" text in my sig a hyperlink.
    I'm a BIG believer in the power of intelligent online communities. Nice work with this site. It certainly seems to have collected quite a few folks with very specialized, in-depth knowledge that they're more than willing to share.
    Julian
    13K gal - IG gunite/plaster - 1 1/2 HP pump - 300lb. sand filter - SWCG
    Support TFP!
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Julian,
    You need to insert the proper codes, etc. before and after the info you would like in your sig. For Example, Let's say you want to put a link to becoming a lifetime supporter. In your profile setup screen, you will need to put the following info.
    Whatever name you want
    So, you want "Be a Lifetime Supporter" in your sig. Type in the code at the beginning... Don't forget the website link, then type BE A LIFETIME SUPPORTER, then type in the ending code.
    [code]
    [/code:3knlvhpd]
    Put all of that information on one line with no (o) spacing and it should work for you. Post again if you need additional help. Hope I have helped in this explanation.
    BTW, Here is what the finished Product should look like: BE A LIFETIME SUPPORTER
    edited by SB, to include [code] tags so html would be visible.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Aug 2007
    Denton, TX
    48
    Thanks!
    Support TFP!
