Results 1 to 16 of 16
Thread: Double whammy skimmer night
    Jul 2007
    Suwanee, GA
    528
    Well only a week into pool ownership and I had my first skimmer surprises tonight. I checked the shallow end skimmer and found a nice dead mouse floating around in circles. And of course this had to be the skimmer basket without a handle on it. Well, I got him out and dumped it in the woods. I went to check the other skimmer and I had a nice little lively frog swimming around with the leaves. I got this basket out a bit easier and I sent Mr. frog hopping into the woods as well.
    With these surprises in mind, I need a better handle on these skimmer baskets. The one that has a handle is pretty much flush with the top of the basket and with a load of leaves in the skimmer, I can foresee having to dig my hand in there and search for the handle. Not a good thing given my surprises tonight.
    Joys of pool ownership!
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Butterfly's Avatar
    South Carolina
    10,045
    We don't have handles on our skimmer baskets, but I never stick my hand in there without seeing everything first (too chicken)! DH has two different size fish nets that I use to swirl & scoop until I can SEE everything. Then I just lift one side of the skimmer sock & pull it out. Then recheck w/ fish net, clean basket & sock & replace. I take a clean sock w/me so that I do it all at once. This works for me. Also, I check my skimmer often & try to keep it clean.
    Hope this helps!
    Joyce
    Attached Files Attached Files
    You're done SLAMing when:
    sammm's Avatar
    North Richland Hills, TX
    257
    I cut a length of weedeater line, threaded it thru the skimmer basket and knotted the ends. Will stay upright and works great!
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Jul 2007
    Suwanee, GA
    528
    The fishnet is not a bad idea, it ran through my mind last night trying to get the cridder out of the skimmer.
    I was thinking of some sort of wire handle, but was worried about rust or corrosion. Trimmer line is worth a try.
    I may also try to fabricate a hook on the end of a stick or pipe so I can lift the basket out.
    Gary
    Houston, Texas, USA
    148
    Yeah I stuck my hand in the skimmer one time without checking it out first. Got stung by a still alive wasp. Ouch. Mine does have a handle. Seems to me you could make a hook out of some wire to pull it up with.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Jul 2007
    Suwanee, GA
    528
    Got home today and there was another frog in the skimmer, probably the same **** one. I found an old baluster from the deck railing demo that had two nails sticking through. Stuck the nails into the basket and it pulled it right out. Came in handy considering it did not require any effort on my part.
    Gary
    Arizona
    925
    Please do be careful sticking your hands into the skimmer basket.
    I found, on one occasion, a hypodermic syringe with needle in one of mine. You just never know.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jul 2007
    Suwanee, GA
    528
    Wow, sounds like some pretty wild pool parties over there.
    Gary
    Arizona
    925
    Not thrown by me.
    Actually, I think it blew into my pool during a big storm.
    Buggs
    N.E. South Carolina
    68
    Ever since the first time I had to get a dead mole out of my skimmer, I bought some kitchen tongs to use. My skimmer baskets have handles, so I remove the top of the skimmer, use the kitchen tongs to grab the handle, and then dump it out. I can even use the tongs to remove the dead critters from the basket itself if necessary. We get spiders in our pool (I guess they are going for the water), and sometimes they are in the skimmer basket still alive. Don't want to stick my hand in there!
    Judy
    Designated "pool girl" for 18' x 40' in-ground vinyl pool built in 2006
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    I have posted this one before but thought it warrants a revisit. I don't think you could grab this guy with tongs... I can handle everything except for snakes
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    sammm's Avatar
    257
    Quote Originally Posted by divnkd101
    I've pulled many a frog out of my pool, but nothing like that! Everything is bigger in Texas. 8)
    N.E. South Carolina
    68
    That's not a frog, thats a dog with really weird feet.
    Judy
    Ohio
    217
    my personal record for one night with frogs is 14. i'm glad they didnt way 10 lbs. each! They can keep you jumpin
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    Kinguni's Avatar
    Winnipeg, Canada
    144
    I had too many frogs (much, much smaller than that one) to count one morning after a storm the evening before. Skimmer basket was full with frogs and leaves (I'm sure at least 20 frogs), skimmed over 20 live ones from the surface with a leaf net, and probably the same number dead from the bottom of the pool. A very wet spring/early summer proved a boom to their population it seems. I have a highway with a large ditch behind my property so I imagine it provided good frog breeding this year. A normal year it would dry up before they could breed too much.
    Other than the frogs I've had one dead bunny in the skimmer, and one dead mouse on the solar cover this year.
    My skimmer basket has a handle on it but I do not pick it by the handle, had a live snake eating one of those little frogs that have jumped in last year, I use my little garden rake to pick it up. We also have those large lovely spiders that love our pool. Yuck
    Brand new (June 1, 2007) in-ground pool.
    Pebblesheen over gunnite 12,500 gallons.
    First pool ever. DE filter.
    Attached spa with spillover into pool.
    Semi-desert climate : no leaves, high evaporation.
    Very light bather load.
