Results 1 to 9 of 9
Thread: Tea (looking) stains on vinyl liner
    Jun 2007
    scottsdale,az
    19
    I have an inground vinyl lined pool. 10,000
    These are my numbers
    I shocked last night because I had some algae..
    With my test kit I'm pretty much guessing at the chlorine after dilution 10ppm Free & total look the same - hard to tell.
    Cya 70
    TA is 120
    PH is just under 7.5
    Calcium changed from pink to clear around 600 but never turned blue.
    The water looks clear and beautiful.
    I have these tea stains on the liner. I've tried the asorbic acid in a pantyhose overnight - nothin'
    I tried the Mr.Clean Magic Eraser-nothin' I only succeeded in removing a little ink from the liner.
    They aren't just on one side of the pool or the other.
    One thing I have noticed is that they buddy up! Like, they're afraid to be alone or something. Where there's one, there's another.. two or three together.
    As you can see from the photos, they're very light but when the pool is clear and still I can see them and it makes me nuts.
    They started appearing last year- one area ..then another. I always thought I could put a little Vit C or use the eraser on them and didn't need to worry about it. Now that I've done those things- I'm worrying about it.
    Oh, I also have a heater that I don't use. It's only about two years old.
    Whattaya think?
    10,000 gallon in ground vinyl liner pool. 1 HP AO Smith Corp motor 3450 rpm, Nautilus Pac Fab Filter DE. Raypak Gas Heater.
    Try rubbing them gently with a trichlor puck and see if that helps.
    Jun 2007
    scottsdale,az
    19
    I tried that and it didn't work. I'm stumped. I just went out and put a little chunk on top of one of the stains. Even if it bleaches the liner a little bit, it's better than the stain. I'll watch it though so it doesn't eat through the liner.
    Thanks for replying.
    Jun 2007
    Charleston, SC
    151
    I get those as well, but whats even wierder, is that mine seem to come and go.
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    Jun 2007
    scottsdale,az
    19
    ..didn't work.
    I'm concerned that there's rust underneath the liner and it's coming up through..
    that doesn't even really make sense but I'm totally guessing here.
    There are various things that can get behind the liner, rust, algae, mold, water, which can cause discolorations visible on the front. They are generally very difficult to treat without replacing the liner.
    mbar's Avatar
    Ashland PA
    257
    Do the stains come and go? If they do, then I doubt that it is under the lliner. How did you apply the ascorbic acid? Did you ever get a true reading on calcium? If you used the drops to over 600 calcium, then that could be a problem - maybe dirt encapsulated scale. YOu can try rubbing some ph down on the stains. But mostly I would like to know if they come and go, and if your cheistry has been consistant.
    16x33 fiberglass pool sand filter
    Jun 2007
    scottsdale,az
    19
    If I'm being totally honest, my chemistry has not been consistent. I've been much better about it recently which is why the stains really bother me.
    I put the asorbic acid, crushed in a pantyhose and placed it right on the stain.
    Our water is very very hard here in arizona. When I run my hand and toes over the stain, it doesn't feel any different than other parts of the liner.
    ..and no they don't come and go..sometimes they seem lighter than other times. I think when it's super bright outside I'm just blinded by the sun
    mbar's Avatar
    Ashland PA
    257
    Since the ascorbic acid didn't work, and the stains are not rough, it may be that they are coming from under the liner. I just am reluctant to believe it because the stain from under the liner is usually black, or very dark. If it were my pool, I would take the ph down to 7.0 - 7.2 and add a metal out (sequestering agent) as per the directions on the bottle. Since you have high calcium in your area water, you probably have high calcium in your pool. It is just a thought, and it won't hurt to add the sequestering agent, and it may lighten the stains or remove them. I like to use Proteam's Metal Magic. Let us know how you make out.
