can you have algae with no CC and FC available?
Oct 18, 2007
104
Central Texas
I have some green spots on the lights and drain covers which scrub off. Looks like algae but I have no CC. FC is available. Is it possible to have algae with no CC?
FC 3.0
CC 0.0
pH 7.4
TA 60
CYA 30
CH 960
PH rise is a constant problem but I do have a large water feature that aerates.
If there are areas of poor circulation then algae can form there, but the places you describe shouldn't have poor circulation -- especially not the drain cover assuming the drain is working (are you sure it's working?). There could have been some biofilms formed there at some point that take higher chlorine levels to get rid of so shocking and brushing are the right prescription at this point and then see if it comes back again after you get < 1 ppm FC overnight loss and let the FC drop back down to normal levels.
You might also check behind the light in the light niche for algae and check under any removable ladders as well.
