I am replumbing my equipment pad, and had planned on placing a check valve before the pump. On occasion when pumping my DE filter, DE will flush back in to the pump basket. The only check valves I was able to find were spring loaded, solid body. Should I use these, or just skip the check valve altogether? The pump basket cover will be just about 1/2" lower than the level of the pool water.
