Thread: Pool aereation and SPA's
    saraiks's Avatar
    Jul 2007
    Fremont, CA
    74
    I have a Spa which is connected to the pool with a small spillway and shares the pumps etc. Is it OK to run the Jets for Aereating the pool water to raise the pH? I will have the water coming in to the pump from the pool, going through the filter, into the SPA and back to the pool.
    16,000 G in ground Gunnite (plastered) with attached Spa, Gemini 3 NG Heater, Sta-rite cartridge filter, Aquabot Mark V, TF test kit
    Yes. Spa jets are great for aeration and will raise the PH quite quickly. Just make sure that there is enough flow into the pool so the PH in the spa doesn't get out of hand. The first time you try this it is best to be around so you can see how fast the PH is rising and make sure there is enough mixing with the pool.
    saraiks's Avatar
    Jul 2007
    Fremont, CA
    74
    Any rough idea on how quickly will it do so ?
    There are so many variables, TA, PH, amount of aeration for your particular jets, size of pool, temperature, that I can't make a serious estimate. I would guess a couple of hours to a day. If you watch it for a couple of hours you will get a good sense of how things are going.
    Just keep in mind that the PH rise will slow as the PH rises. If you really want to speed things along add acid every hour to get the PH back down to 7.0-7.2.
    Ohio
    217
    I have a stand alone spa so things will be different but keep a eye on the ph for the spa. I dropt the ph with acid and it only took ten minutes to raise back up. I was able to drop 50 in the ta in ten minutes. so watch that ph in the spa
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
