So the yard is prepped, the test kit is ordered, and I'm just waiting to hear from our dealer that the spa has arrived so they can schedule delivery.
Which means I've been reading up on water chemistry until my eyes have crossed!
While doing that, I ran across a forum post by Chem Geek that suggested treating a new spa like a used one and doing a decontamination procedure which I understand to mean filling the spa, super-chlorination, and then draining the spa before refilling and proceeding to balance the water for use.
Then later I found another post by Chem Geek that said any new spa owner should expect to have to do the first drain/fill routine after less than a month of use due to organic contaminants and/or manufacturing residues that will undoubtedly be in any new spa.
Does that mean I should expect to have to fill the tub (paying for the water & heating it ) three times just in the first month?
Or does doing the initial decontamination routine mean I shouldn't have to do another drain/fill less than a month later?
I've got a couple other questions about combining Nature2 with the Dichlor-then-bleach method, but some of them may change based on answers to this question, so I'll hold on to them for a bit.
Thanks much!
-G
Thanks much!
-G
