low alkalinity and high ph
Gail
Jul 22, 2010
25
Pittsburgh, PA
Low alkalinity & high ph. Alkalinity bout 50 & ph 8.3 Keep adding baking soda-then ph minus. Water tested at 2 major chains. I buy & add all chemicals & right back where I started 24hrs later. 27ft 4.6 ft vinyl, hayward missile cartridge. Been at it 6wks, vacumed out 6in & refilled last week. No debris just green algea. Can anyone help? Pool about 5 years old. Southwestern Pa. Water samples say everything else ok.
Re: Testing and Balancing Your water
welcome to TFP. :wave:
You should invest in a good test kit, such as the Tf100 or the taylor k2006.
If you're TA is at 50 (pool stores are known to be way off) you should raise your TA with baking soda to around 90. Then add enough muratic acid to lower PH from 8.3 to 7.6. You can use poolcalculator.com to figure out the dosages. I'm guessing once you add the acid, it will bring your TA to around 70-80, which would be just fine for now.
Read Pool School for more info on adding chemicals and it's effects. You will need a good test kit though.
Thanks. The water sample is done on the computer so I figured is was accurate. Do you disolve the baking soda & should the filter be running when I put it in? How long do you wait to test the alkalinity again? As for the Muratic acid, where do I get it & how do you use it(pool school)? Then what and when for chlorine? The pool store says put this in, wait 15min then put this in, then in 4 hrs add this! Started trying to research myself. Found this site on ASK.
Always have the pump running for at least an hour or two after adding chems. (and an hour before testing).
Pour baking soda in front of the return, slowly and brush with your brush/pole combo. Or predissolve in a bucket of water.
Muratic acid can be found at pool stores, home depot, lowes, etc. places with pool departments but sometimes they stock it in the paint department. There are various strengths so check the labels.
I would add the baking soda, wait 15 minutes, add the acid and let it circulate for a 3-4 hours and retest everything. (do you have your own kit?)
Chlorine is added nightly (if using bleach) pour slowly in front of the return and leave it running for a couple hours to circulate.
No one has been in the pool. Yes I have algea because I have not been able to get the water balanced. Chlorine does not hold more than 12 hours. Went through at least 30 bags shock. The green algea is not clinging to wall, pool is still vacumed daily. Working on balance today, keeping my fingers crossed!
Reactions: RhondaF
Getting a full set of test results is important. I suspect that your CYA level is either too high or two low, either of which could cause all of your chlorine to vanish.
As dmanb2b said right off, nothing will help more than getting a top quality test kit.
Pool store had me add stabilizer last week, it was ok till I vacumed the bottom out, then it was low. If I am starting to understand, when I was adding the pool store shock(3 bags-1 time they said use 5 bags) it was raising my ph(trichlor). Have used the pool calculator. Done the baking soda at 1pm today. Acid at 330pm today. Should I go ahead and add bleach or wait to test water in 3-4 hours for ph & ta? Thought I read that bleach does not affect the ph & ta. Done alot of reading-cramming! Yes I am ordering my own test kit. Up against the weekend, so I would like to keep working on pool till then. My filter is running. Acid & test b 4 bleach or acid & bleach then test in 4 hours?
Remember that the PH test results are invalid if the FC level is higher than 10.
Bring the PH down first. You can test the PH again about an hour after adding chemicals. You want to get the PH in range before doing anything else if you can do it soon (though add chlorine tonight regardless).
After PH is in range, raise the TA, wait a few minutes and then add chlorine.
New test results;
Ph 7.8
Ta 98
CYA 80
TC 0.6
FC 0
Ended up using gallon of acid(20 baume,31.45%), 15lb baking soda, & 182oz of bleach(6%) Yesterday.
Todays results are the best I got so far.
ANY IDEAS????
AG, 27ft 54in, hayward cartridge
You are doing great. Lower the PH further, to around 7.4ish and keep shocking (adding lots of chlorine). When fighting algae, the more frequently you test and raise the FC level back up to shock level, the sooner you will kill all the algae.
Will the Ph rise when I shock with bleach? Thought I read that somewhere.
It'll rise a little when you put it in but it will come back down soon. So, disreagrd that and treat the dosage like it is pH neutral because it is.....it just takes a little time to become neutral.
Water is turning blue. Can't see the bottom yet, but it looks better.
Have not received my test kit yet, expecting anyday now.
New numbers from computer test at pool store.
CYA 65
TC 2.5
FC 2.3
Ph 7.4
TA 96
Tot Hardness 247 (not sure what this is)
Not sure if I am using the pool calculator right, how do I figure out the GOAL(Target) NUMBER.
CYA 65=FC Shock 24-25????????
Just stocked up on bleach.
I know I need to raise & hold the chlorine.
Then vacume??? Bleach??? Vacume??? etc. till clear?????
AG, 27ft, vinyl, round 52 inch,
Got my TF-100.
CYA 30. Did the test 2x, came up with same results. Do you shake bottle, sit for 30 sec then another shake, then use? Kept adding till I could no longer see black dot while looking down on it. Last Pool store result on 2 days ago was 65. Did I do it right? Do I keep puting in drops till dot completely gone, or when cloudy shadow of it?????
Trying to do the TA test now. Am I watching for the whole solution to turn red or the drop when it hits the solution?????
If I understand this right I can't test Ph cause I am at shock level with chlorine.
Pool was cloudy blue this morning till I vacumed, bringing up some light green still. Off work today, so trying to figure it all out. Back 2 work tom.
Figure I would try to get right cya reading today-bleaching for cya 65 now.
Wanted to check TA, then use pool calculator to figure out FC level.
Should I check any other test today?
Plan of action?
AG 27ft, 52in, vinyl, cartridge filter
