Results 1 to 9 of 9
Thread: Build SPA with new pool or NOT?
    Aug 2007
    Austin, TX
    343
    I am in the design phase and wondering if there are any benefits to including a SPA in my new pool vs. a standalone spa? The only reason I am currently looking at installing a SPA is for the looks.
    I am interested in learning beside saving on the up front costs of not including a SPA with my pool, if I would save long term costs on heating & chemicals? Any thoughts are welcome.
    Thanks in advance!
    Mike
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Having a spa that is on the same plumbing as the pool offers noticable operating cost and time savings compared to having a separate spa. The build price is generally lower as well since some of the equipment can be shared. If you are in an area where you need to winterize your pool, having a spa on the same plumbing makes winterizing the pool a little more difficult and makes it either very difficult or impossible to run the spa when the pool is winterized.
    I'm in Virginia, and one of the pool builders we consulted for an estimate talked us out of a built-in spa for the reasons that JasonLion stated...once the pool is winterized, the spa is out of commission. Said we'd be better off getting a separate unit. DH really wanted one, and I must say that I like the looks of the built-in spa as well...although I tend to pass out in them so I'm not pushing the matter too much
    On another subject, JasonLion, I grew up in Silver Spring...first in the Kemp Mill area then moved "west" to Colesville and Olney areas before crossing the border into VA!
    inground gunite, 18x38 freeform, 3'-9' w/ diving; 3M caymen green/blue blend; Pentair 2HP whisperflo; + aux pump for water feature; SWG; Rheem heat pump; Polaris 380; Pentair TR 100 sand filter; silverlake flagstone coping/broom finish concrete deck; NPTG Aztec cobalt tile; 18" bond beam wall with water feature
    One option if you really like the look of a connected spa but want to be able to run it in the winter with the pool winterized is to put the spa next to the pool and make a fake overflow/spillway, a waterfall right between the spa and the pool where the water comes from the pool not the spa even though it looks like it comes from the spa.
    I moved to Silver Spring eight years ago, used to live in Massachussets. For many years we were in downtown Silver Spring. Last year we bought a house right near Colesville.
    From_Arizona's Avatar
    Glendale, AZ
    212
    Some of this can be personal opinion. I am very happy with our above ground spa and woudl not think of building one in the pool. My spa is very easy to balance the chemicals, the spa fits me perfectly and the surfcae of the spa is smooth and comfortable. It does not have that perfect aththestic look, but I am planning to beuilt a wall around it to blend in with the new pool deck color and rock look.
    1980's Shasta built 30,000 gal inground diving pool. Pebble-tec interior. Pentair DE Filter. In ground pop-ups. Hayward Navigator sweeper.
    Arizona
    925
    I think the above ground spas are a lot more comfortable, too - or they are compared to any built in pool/spa combos I've ever been in.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Aug 2007
    Drifting the watelands of NJ
    35
    newbie here with Pool under construction......that being said I've owned a Spa for the past 5 years. no way would I put a spa in my pool. (My builder was offering one free with the pool and I had him just add the additional 50 square feet of space at the end of my pool with seats but no jets and no wall between pool and seating area. I live in NJ and I use my "hot tub" 8-9 months out of the year. the best time is when it's 20-40 degrees outside! My neigbors have spa attached and rarely use theirs. I mean who wants to sit in 100 degree water when it's 90 outside? Plus the seats are all bench and the jets just randomly placed as opposed to my spa which has all types of seats and the jets are placed for maximum therapy. With a seperate pool/spa combo you can be outside in water 12 months a year!
    35,000 gallon 800 Sq. foot gunite, 50 x 22 freeform. 2 sheer Descent waterfalls from 2 foot raised beam wall, Jandy heater, Polaris 280, 2 H.P. pump, DE 60 filter, Nature2, 2 Jandy color lights, 1000 Sq foot of Stamped concrete.
    Master Spa LS850
    Sep 2007
    Gloucester County, NJ
    141
    have spa...kids love it
    we went with a spa...the kids love it! I can't wait to be able to turn the heater on (another two weeks)
    HPDRIFTER - sounds like you got your pool from Swim-mor...where in SJ are you located?
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    DaveNJ's Avatar
    Toms River, NJ
    520
    I agree a stand alone spa is more comfortable and and better jet placement. I use mine (spill over) in the evening after work. Don't mind closing it for the winter with the pool. As I'm getting older going from cold to hot water and cold again doesn't appeal to me.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
