Results 1 to 7 of 7
Thread: ph increase
    Jul 2007
    ontario, canada
    85
    ph increase
    Well here I am with yet another question.
    My ph is up to at least 8.2 over a period of a week. I was away for a bit and had someone adding a little bleach each night for me, so I'm not sure when exactly it happened. pH was 7.4 when I left.
    My alkalinity has dropped from 100 to 80 but over a more gradual period of time. My FC is at 5.
    I've added some pH decreaser (something left over) tonight and I'll check it again in the morning but because I can't tell exactly what's in this product I'm not sure how much of a drop I should expect...trial and error 'til I move on to the muriatic acid. I guess I'm more interested in learning why this would happen.
    Can anyone help me with this please?
    Thanks
    16x32 inground vinyl liner approx 23 000 gallons
    22" cyclone sand filter, 1 HP pump
    solar cover, solar heating panels
    Taylor K-2006 test kit
    PH can go up for a number of reasons. The most common is CO2 outgassing caused by aeration of the pool (rain, kids playing, SWG, waterfall, spa, etc). Blown in dust can sometimes be fairly basic, raising the PH. New plaster will raise the PH for several months to a year.
    If you compensate for PH increases from CO2 outgassing by adding acid reguarly, the TA will go down over time.
    Jul 2007
    ontario, canada
    85
    Hardly any rain lately...very dry right now, no kids, no SWG, no waterfall/spa or fancy things I dream of owning No plaster and no reason for there to have been much dust. My returns do aerate a little I guess, but they're not doing anything that they haven't been doing for the rest of the summer, so I guess it's still a mystery.
    There is only one more I can think of right now. If your FC level is above 10 the PH test can read higher than the actual PH. Other than that I'm stumped.
    Jul 2007
    ontario, canada
    85
    Nope...if anything I had to panic for a moment when I got home and the level was lower than it should have been...when I took that reading the FC was actually at about 2.
    I remain stumped too
    Thanks or the suggestions though...I've learned something anyway.
    Mar 2007
    San Rafael, CA USA
    12,082
    If your pH Decreaser is dry acid crystals (sodium bisulfate), then one pound of these crystals is equivalent to about 12 fluid ounces of Muriatic Acid.
    Jul 2007
    ontario, canada
    85
    Yes that's what it was...thank you for the conversion
